If ya'll wanna get techincal about VIN codes...'87-'92 FLEET (Cop, Taxi, Fire) Crown Vics are P72, '93-current POLICE Crown Vics are P71 and FLEET (Taxi) are P72s. '87 is when the P7x codes started, before that they were P4x.
the police car we have is a 1989 and the wiring is much diffrent from the non police models the alternater on our's went out so we tryed to use the one from the grand M and it would not fit so if you take the alternater take the wiring too and the police car has a power steering cooler of sorts and a oil cooler i'd use the parts from the power steering cooler and add an oil cooler to it since the steering cooler is just a hard line in a loop plus it can hold more fluid with a better cooler grab the spottlights
The police model got a 100 amp externally regulated where most civi cars got a 65 amp internally regulated. The 100 is the same as the one on a Mark VII. Unless you already have a 100 amp jobbie tho, its not worth the hassle of installing one since the 3g is a higher output and less work to do.
The line from the in-radiator trans cooler to the external trans cooler is great to have. You can install an aftermarket cooler that performs better, and still have that nice clean cooler line install. The coolers are OK, not great, but installing a 20 year old cooler with unknown garbage in it may not be the best idea for the health and welfare of your transmission.
You could save the hassle of putting the police alternater in by getting a high output aftermaket mustang unit in like a powermaster 140 or 200 amp alternater that is if you need one that big. oh and over here new police units are hard to get so we had to rebuild it
i've gaot the tow package on my car so the brakes wouldnt be an upgrade i don't think. the guage cluster is already pulled and going to somone else. i'm working on a digital set up for mne i just haven't had the time to finish it. but ill nab the sway bars and the powersteering cooler sounds cool. no spotlight on this one and it has bench seats. no three pack of guages either but i does have the the 351 in it. any thing else i should look at????
sigpic"I love it when a plan comes together." Hanibal Smith (A-Team)
the rear control arm's on the police car have the bolt hole's to mount the anti sway bar so you want to grab those too. the stock rear control arm's have no bolt hole's
