Is this an HO governor?
Tags: None
Thanks TrapSpeed.
SO I guess this is my next question...... Should I just go with a trango Hi rev kit> Brings the shifts to 4900 or so. Will have trick flow 170 twisted wedge heads, gt 40 lower intake with tubular upper all on top of an HO engine. I am thinking that may be the real thing to purchase for my build but would like some input.Last edited by 87gtVIC; 08-07-2014, 05:32 PM.~David~
I thought the standard HO gov set the shift point at around 5K dead to shift it by 53-5400. considering I read the numbers like 4 or so years ago on here... I'm probably off a bit.
Oops I made a boo boo. The transgo kit makes your tranny shit at 5500. I honestly do not know where the Ford HO governor sets the shifts at.~David~
4800 or so.
I had a conversation with the Ford dealer parts guy. He's a walking talking Ford encyclopedia. Of course I forgot a lot of the conversation, but he mentioned something about using the Transgo hi-rev governor instead of the HO one (which is what I went there looking for). That will shift it at about the same revs as the HO one. But do not use the Transgo shift kit. Using the shift kit will bring the WOT shift up to 5500. Also there was something about the 1-2 being at a different RPM than the 2-3 by going this route.
Can anyone shed any light on any of this? Did I completely twist what he said into incomprehensible crap?1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
for a standard HO engine that sounds about right. The springs supposedly start to float that high... but with the setup Dave is going with, that shouldn't be an issue till about 6K I would think. Shift kit and hi-rev transgo may be the way to go.
The transgo kit is the way to go. From my own experiences do not install the governor by itself because it needs more line pressure due to tighter clearances and the much lighter weight. IIRC the other 2 springs are for the 2-3 and 3-4 shift valves. The transgo hi-rev kit can be combined with any shift kit. Just make sure you use everything in the transgo hi-rev kit of which is 3 springs and the governor itself.
Appreciate the input.
One last thing I have on my mind....I will be fine installing the hi rev kit into the stock governor or should I start out with a mustang governor?~David~
Pull the governor out of the housing by removing the 2 phillips head screws, remove the c-clip & spring, swap the spring which should be (red) IIRC put the little c clip back on the transgo governor and re-install. Make sure the screen in the housing does not come out and you should be all set. The housing is the same. The piston is what is different and all 3 will weigh in different with the transgo being the lightest in weight and the stock lopo being the heaviest the stang one falls in the middle weight wise.Last edited by TrapSpeed111; 08-11-2014, 11:28 PM.
So no need to purchase the mustang one and then add the kit. No added benefit. Thanks.~David~
Last edited by 88grandmarq; 08-23-2014, 12:07 AM.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Geez, that's a big step between HO and Hi-rev. I wanna be shifting 5000 or so.
