Can’t read codes
    Can’t read codes
    On my My 87 wagon i Can’t read codes
    Has that model reader ever worked for you before? I have a slightly older Actron, which IIRC I bought on your advise. You r welcome to try it.
      ever try the jumper wire and blinky light method? Curious if it does anything, or gives something completely bonkers.
      http://www.grandmarq.net/oldfuelinjection/page13.html
      also in there is what to check if it won't give any codes.
        Reader worked before. I hear fuel pump prime then clicks then no codes on reader.ill check what’s on link
          I had an ECM that wouldn't talk. Ran like a top though. Swapped in another ECM that didn't have a burnt diag trace internally.
            wonder if someone jumped it to +12v instead of ground to read codes
              Considering the redneckery under that hood that I had to fix after I bought that car... probably.
