I recently got a new speedo cluster for my 91... (Mine, the case was all cracked and falling apart from the heat) I figured while I had the dash apart, I would install L.E.D. lights in the cluster, to make it brighter. Also it would be less heat, which would make the speedo case be less likely to crack and fall apart. Has anyone done that here? Was wondering which lights to use, to make it brighter, as well. The dash lights on these cars have alwasy been dim, at best...
I gues what I am needing to know is if anyone did it, and did it make the speedo cluster brighter? And if it did, which ones did you use? (Also maybe some photos "before and after" to see the difference?)
Thanks for any help, in advance... Tom...
