Never looked for it and am wondering where is the exact location? Under the hood or inside the dash?? Thanks....Bobby
ECM on '87 GM (location)??
"Cars are for driving - PERIOD! I DON'T TEXT, TWEET OR TWERK!!!!"Tags: None
Look under the drivers side dash above and just to the left of the brake pedal. You will see the computer there. You must removed the nut holding the bulk connector from the firewall side, outside.~David~
Thanks Dave! The nut you are speaking of is under the hood, I assume? If so, can you get to it from above or under the car (I would think if it that low under the car would be best but have to ask)?
It's under the hood and you can get to it from above it is just somewhat of a pain cuz of the inner fender. I believe it's a 10mm, may be easier if you remove the cruise ball which is also 10mm1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
Wheel well sorta gets in the way more from the bottom unless you remove it.~David~
easy way is to remove the cruise servo then use a swivel head extension (10 inch to help clean stuff) or a u-joint, on a 10mm socket and take it off. Then just yank the ECM out from under the dash.
Wonder why it isn't just bolted in from the dash side??
that would be even more bolts... costs more... can't have that.
Is it only one bolt under the hood? If so, why not do one bolt inside??
It holds the plug tightly to the ECM.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Originally posted by Piece-it pete View PostIt holds the plug tightly to the ECM.
Pete
just like the ignition switch harness. one bolt to "in the darkness, bind them".
