OK, the trunk wiring harness on my 1991 Crown Vic needs to be replaced... it has been jury rigged many years ago, (The plug over the drivers side wheel well fried, so I cut it out and spliced the wires together to make it work temporarily... so now it is acting up again... right side brake light quit working...
So my question is, does the wiring harness plug in up under the dash, or is it wired directly into the fuse panel... I am going to go get the wiring harness tomorrow from the junk yard, if they still have the one they had the last time I was there... So can anyone tell me where it plugs in, (Pictures maybe of the location?) if not, I'll just cut it near the "B" pillar, and splice it, and use some shrink tubing to 1. make it water proof, B. Make it harder to pull apart. C. to make it look neater... I need to get it fixed tomorrow, (Monday) since I'm off....
