I have a 3G alternator that is waiting to go in whenever I get around to acquiring the wiring and circuit breaker. I recently picked up a new Motorcraft GP712 pulley for it. This pulley fits a lot of different applications originally equipped with a 3G alternator and is the same size as the 2G alternator pulley, allowing me to use the stock belt whenever I do the swap.
That being said, I want to make sure that I won't be over-spinning the alternator or over-charging the system with this setup. I have the higher amp version (two holes) and will be installing 3.73 gears in the near future.
