how do i test for codes 41 91
codes 41 91
when do you get these codes? key engine off test, Key on engine running test, continuous memory test?
basically the codes are saying both O2 sensors are reading lean, start by checking for vacuum leaks and/or extra air getting in the engine. check the MAP sensor and the vacuum line going to the intake manifold2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Whats the car and is it stock?
What he said about what the codes mean, but what causes it could be a lot of things depending on what exactly you have under the hood.86 Lincoln Town Car (Galactica).
what MAF and what ECM? if its not the MAF for that ECM it might do this. If the sensors are switched left to right, or if the smog pump is installed but the bypass valve is bad it will do this too.86 Lincoln Town Car (Galactica).
Originally posted by rellik god View PostA9p 94,95 mustang mass air no smog and left and right o2s hooked up right ground wire hooked up2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Actually, I misunderstood your original post. The 94-95 GT MAF is a direct swap with earlier mass air computers. No extra tuning or wiring modifications are necessary.
—John
1985 Ford F-150 XLT Lariat
how is your PCV air feed connected? It should go to the throttle body with mass air.
part of the trick with a MAF is that the airbox and the air tube is part of the calibration. Non-stock air cleaners, and cone filters especially, can screw with how they respond.86 Lincoln Town Car (Galactica).
pcv air feed from valve cover to throttle body. FORD 2004 + PI AIRBOX ASSEMBLY FORD PI INTAKE TUBE
is there any way to test o2sensors i dont remember how old the are off hadLast edited by rellik god; 10-16-2018, 09:00 PM.
there is a way to do it with a meter and a propane torch but if both read lean, its probably not both sensors going bad at the same time. on the rare occasions I've had a bum sensor, it didn't give any codes.86 Lincoln Town Car (Galactica).
pulled o2 harness and found two ring terminals for ground.the larger ring terminal brown wire was not going to ecu so i pulled harness off and checked pin 49 which was the orange wire and it checked out.what i did was ad a ground wire from head to body and when i hooked things back up i used the big ring terminal brown wire instead of the orange wire.did koer and no more codes 41 91
