Dash are 5 inch using 3 screw mounts that require spacer rings to mount 4 inch speakers. There will only be wires to locations that are currently loaded. If you have door speakers, you don't have dash speakers and vice versa. In the Mad Marquis, I ended up deleting the dash speakers and running that speaker wire down and into the doors and running 6.5s in the doors. Worked much better for me. I did have to drill the holes for the screws to mount in the door though.
The speakers you have listed are good. Also, ordering from Crutchfield, they should include the speaker adapter harnesses (at least that's been my experience).
