No Heat in 1990 GM - BDA, Heater Core, or Temp Sensor?
Vic
Thanks for the help, guys. That list of hoses is quite useful. I'll buy the heater core and the necessary hoses today, so hopefully next weekend I'll get this taken care of and have heat once again for the first time in years.
For now, I'll just leave the TBL as-is. Since this heater core replacement is a bigger job than I've attempted in the recent past, I'm slightly wary about doing too many things at once in case I somehow screw up and need to figure out what exactly went wrong. But I'll definitely keep that in mind about bypassing the TBL if I need to do so in the future.
I am, however, going to replace the variable-speed blower control, because that is not working and hasn't worked in the seven years I've had the car. Never bothered me that much, but since it's right below those hoses that I'll now be removing, I don't really have an excuse for not taking care of it.
I'll post an update after I've (hopefully) gotten things in place and working.
half the time its just a crusty connection, but the resistors do die. I think a '90 still uses the old resistor style. if its the modern electronic one, those usually just have broken solder joints that can be fixed for no $.86 Lincoln Town Car (Galactica).
So I managed to successfully get the heater core hoses off without cutting them or otherwise damaging them. I bought and used some hose removal pliers, which worked quite readily. And then I unscrewed the retaining nut right next to the heater core hoses.
I'm having trouble on what I guess is the very last step, though. No matter how hard I pull and which angle I come at it from, I can't get the heater box to move. It's quite loose at the left side, the right side, and the bottom, but it's as if there's something still securing it to the firewall in the upper-middle part. Like I said, I unscrewed that retaining nut. I pulled the heater box back maybe one-half an inch and it won't budge beyond that, nor can I push it back to its initial position. It's almost like the stud the nut was screwed onto caught on something.
I'm pretty sure I followed every step in the heater core write-up on here, including removing the two nuts at the bottom of the heater box. Has anyone else had issues pulling the heater box out? Is there something obvious I'm overlooking?
I think there is one more screw in there that you may have to access from the engine bay side. I did mine twice but its been a long time and I don't quite remember but thats whats coming to mind.86 Lincoln Town Car (Galactica).
one nut high and one nut low. I know on the 88 MGM I had to remove those from the engine bay side. Reach one from the top and the other from under the car. Also, Seems every year was a little different. So there may only be one of those or both.
I looked back at the guide to refresh my memory.
For '91, and I assume '90 is the same, there is only one nut to worry about in the engine bay. It sounds like you got it. That's the only mount for the top of the box, but it may be wedeged in its hole in the fire wall.
Since the bottom is loose, it sounds like you got the only other two mounts for the heater box. Bottom of the box near the passenger feet area.
So it sounds like the only thing you have left is to pull the box away from the firewall. Either the stud or core lines are caught into the firewall or something acting as an adhesive. Nothing else that I'm aware of based on my experience with a '91.Vic
Thanks for the tips, everyone.
I have the 1990 car shop manual, which has been useful for some things, but its directions for removing the heater box were a bit of a head-scratcher. Your helpful guide for the 1991, VicCrownVic, was much easier for me to follow than the manual. Now that I've done (most) of the work, the directions in the 1990's manual are making a bit more sense. But they do leave me wondering if there is indeed an extra nut (or nuts) somewhere on the 1990 that isn't present on the 1991.
Here are some pictures in case this is of use to anyone who comes across this topic while working on their 90 in the future. Step 4 in the manual refers to three nuts below the windshield wiper motor. I don't think I ever removed anything like that, and I'm not even sure I see them in the engine bay based on a quick look. But that could be one possibility for what's holding in the heater box at the moment. Perhaps these are those lower nuts that they're referring to as items 13 and 15 in Figure 23? It seems like I may need to get under the car to access these. Step 16 refers to "two nuts from the two studs along the lower flange of the plenum" -- pretty sure those are the ones I removed under the glove compartment. The manual also seems to suggest (Steps 14 and 15) that there are some extra screws and a push pin attaching the far end of the heater box to the floor air distribution duct. Not sure whether removing those will make things easier.
In any case, I'll do some experimentation tomorrow to see if I can find what, if anything, is holding in the heater box.
Below the windshield wiper motor makes no sense to me whatsoever. The windshield wiper motor is way over on the driver side.
The three nuts that it is referring to I believe are three 15s in figure 23. Since you removed the two lower nuts from the inside there should be no need to remove those two lower 15 nuts on the engine bay side. Now nut 13 seems to be sandwiched between one of the 15 nuts, the the evaporator housing and the firewall (engine bay side). I'm not sure how easy that would be to get at, but again, if you have removed the interior nuts at the bottom of the heater box, I don't see any reason the engine bay side lower nuts (both the lower 15s and 13 in figure 23) would need to be removed. If I'm understanding you correctly,Originally posted by SomeoneWeird View PostIt's quite loose at the left side, the right side, and the bottom, but it's as if there's something still securing it to the firewall in the upper-middle part.
Originally posted by SomeoneWeird View PostI pulled the heater box back maybe one-half an inch and it won't budge beyond that, nor can I push it back to its initial position. It's almost like the stud the nut was screwed onto caught on something.Last edited by VicCrownVic; 11-29-2020, 01:18 AM.Vic
Yeah, I suspect you're right. The heater box does seem to be more or less loose depending on how I position the driver's side of the dash, which is part of what made me think I'm missing something over there, but I suppose it wouldn't be a nut that attaches to the firewall which is responsible for that. Anyway, thanks again -- I'll do as you suggest and I'll post an update once I've managed to get this darn thing out.
On a related note, I did at least manage to get the blower resistor out. Gadget73 was right that the only thing (visibly) wrong with it is that's it pretty crusty (see picture). The female connector it attaches to is even worse. Is there a preferred way of cleaning these out which won't damage the hardware?
I thought about buying a replacement just in case something non-visible is wrong beyond the crust. But it looks like aftermarket versions of this part for cars with ATC aren't even made. RockAuto lists some aftermarket parts for the 1990 model year, but it seems it may be erroneous. Some other websites only list the aftermarket part for 1991 onward. And pictures reveal that the contacts on the aftermarket parts are a totally different pattern than the contacts on the OEM part in my picture: https://www.rockauto.com/info/577/1712211-1__ra_p.jpg (Is this an actual difference between the 1990 and 1991 models, I wonder?)
I do happen to know that the blower motor speed controller (BMSC) is functionally the same between a 1991 MGM and 1997 LTC. When I swapped the ATC control head from a '97 LTC in, I figured this out based on electrical schematics that seemed to indicate this including wire colors being the same. I have never seen the BMSC connector, but would imagine it is the same for '90+'91. The replacement comes with a new connector that is spliced to the original harness. Some of the same replacements are listed for '90, '91, and '98 MGM. I have no idea why all the ones that come with a new connector are not listed for all those years. WVE 4P1593 listed under '91 MGM but not '90 seems to be the cheapest option. since other parts are listed for all three of those years, WVE 4P1593 should work for '90. Other parts listed under '98 without the new connector use the same connector which tells me the service procedure for '90+'91 must have changed to use the new BMSC with new connector and the old '90+'91 BMSC must have been discontinued.
In other words, junkyard or NOS is the only way to get a replacement BMSC that does not require splicing a new connector in.Vic
The more I thought about it, the more this scenario sounded familiar. http://www.grandmarq.net/vb/showthre...l=1#post738768
What might be happening is another nut on the engine bay side on the same stud you already removed the nut from but behind the plastic. Number 13 in fig 23 (although that figure seems to indicate 13 is only on one of the lower studs.) I would not bother with it since posts on the last page of the writeup seems to indicate that there is a nut on the top stud in the cab that can be removed. The stud would then remain in the firewall when the heater box is removed (might want to put the nut in the engine bay back on.)Vic
What usually fails on the BMRC is a solder joint inside the unit, or at least thats how later ones die. Pull it open and have a look.86 Lincoln Town Car (Galactica).
Originally posted by VicCrownVic View PostThe more I thought about it, the more this scenario sounded familiar. http://www.grandmarq.net/vb/showthre...l=1#post738768
Sounds like what they're saying in the posts right above and shortly after the one you linked is that I need to peel back the insulation to access a hidden nut. I should hopefully have some time to attempt that and also pop open the VSBC and look for any solder joints that have failed. (I'll also try to use some 99% rubbing alcohol to clean off that crustiness as best I can.)
Update: I was successful at getting the heater box out, removing the old heater core, putting the new heater core in, and repairing the broken solder joints on the variable-speed blower control.
There was indeed a nut obscured by the insulation that I needed to remove before being able to take the heater box out. I didn't actually have to remove any insulation to get at it, just push it stiffly out of the way. The nut was way behind where the BDA unit is situated and was accessible with a 9-inch drive extension bar for my rachet.
Anyway, I'm now in the process of putting things back together, and I came across something that I think may have popped out when I was taking things apart. Does anyone know what this hollow rubber tube behind the glove compartment is supposed to connect to? Presumably it's not just supposed to be hanging free (...or is it?). I looked around for a little while but couldn't find any obvious connection for it.
Thanks everyone for all the help! Couldn't have done this without your guides and tips.
