I found door panel lights for my two door, I have the connector for the lights already in the door from factory, so I plugged them in, but they dont work. I checked for power and ground and had nothing, followed the connector and wires into the car and found a connector unplugged behind the glove box, couldnt find the other connector for it to plug into. does anyone know whether or not I have to get the harness out of the donor car or is the other end of the connector hiding where I cant see it? Thanks for reading.
Door panel lights
I think only the mercury and lincolns had that pre wired. I could be mistaken though. There's no connector in the door, the wire comes from the kick panel area IIRC and is wired into the door. I don't remember an intermediate connector on either the 82 Lincoln or the 88 Mercury I had. Both had door lights and the Lincoln was a Mark VI 2 door.
Hate to add to the confusion....on my 87 CV two door it was almost fully wired in and I just had to get bulb socket and solder it into the existing harness....mercury panels/lenses and plug them in. They worked right away!
Vague install back in 2017
