I got an 85 GM and a PO wired the radio directly to the battery, and I'm in the process of properly wiring it back in. I also have no gauge illumination, and I was wondering if the gauge illumination ran through the radio wiring like on some cars?
Gauge cluster illumination
No, but there is a connection from the dash lights to the radio. If someone shorted it you may have just blown the fuse. Should be the only 3 amp fuse in the box.86 Lincoln Town Car (Galactica).
All fuses were good on the under dash block, got the cluster somewhat pulled out and the bulbs didn't appear burnt out, haven't tested for power because it started raining before I could get the speedo cable off to pull the cluster out completely
The power for illumination comes from the headlamp switch. This is a known failure point with the massive wire harness liking to melt in various ways. That could be the issue.
Should be the brown wire.
Originally posted by sly View PostThe power for illumination comes from the headlamp switch. This is a known failure point with the massive wire harness liking to melt in various ways. That could be the issue.
Should be the brown wire.What I Own: 1993 Mercury Grand Marquis GS
The quick connects used get crusty and create resistive connections and then get hot and just get worse as the plastic harness degrades due to the heat. This is the reason for the relay mods that dump all the current through a relay instead of the switch.
check traces on the cluster. Check for cracks and oxidation on the connector. May just need a good cleaning. May have a bad ground for the lights. Check both ends of the circuit. I think there's a couple of grounds coming out, but just follow the traces. They're pretty easy to follow. If you run across any cracks, defroster trace repair kit works (or conductive epoxy) pretty well if you're not real confident in soldering skills since the film will melt pretty easy.
+1, traces are easy to follow. Look for traces that have lifted away at the connector. If the cluster has been out previously, it's a possibility.
If you have a multimeter, check for continuity from the correct cluster connector pins to each light socket unless you find an obvious break like Sly described. If you need the pinout I can get it later if I remember, or someone else might have it already.Vic
A question I would be interested in hearing suggestions on as well.
I used some glue but don't remember what I used. Super glue might react weird with the materials involved. If its a trace where the connector connects you will have to scratch any glue off that gets on the contact surface.Vic
cv/merc clusters are very different.
A little dab of rubber cement, contact cement (non aerosol... good luck with that), shoe glue, some other flexible adhesive should probably work just fine. As long as the trace is all there and not torn, you should be able to fix it pretty easily just by laying it flat and putting some stick-it-down goo between the trace and film backing. Just be sure the contact area stays clean on top.
