Front Bumpers?
    Front Bumpers?
    I found a front bumper at the JY this morning that's in better shape than my mom's CV. It is the standard rubber strip bumper. I would like to re-chrome the bumper before or during the final phase of the CV rebuild (paint). What do you guys do with the rubber strip? Can a new one be bought? Do we just leave it off. Or do we need to take extra-special care when taking them off, so we can put them back on? Just curious.
    You have to take the inner bumper appart from the outer. Then with a pair of plyers or somethig similar sqeeze the plastic nubs protruding inside the front of the bumper that hold the strip. Then push the nub through the bumper. Dont sqeeze to hard take a couple to get the hang of it. Care must be taken so you dont snap them off. The strips are hard to find. Trying to remove them without dammage is a crap shoot with out dissasemmbling the bumper.
      I have luck removing them on hot summer days. A month or two back I removed a set with Ivan. I used a flat nylon pry bar to just lift the edge up a bit then slid a metal angled pry bar (more like a door panel tool) and slid that between the rubber and the first tool. Then I gently pried up. Once you have one push pin area removed then I moved to the next.
      Or you can do like Dave said.
        If you're rechroming, i'd have the platers remove it. That way it's their job to replace it if it's fubar.
          ^ I understand what you are saying but I would personally never do that. I have come to know way to many businesses that just don't give a fuck. Do what you can by yourself and avoid the headache of dealing with dumb excuses.
            We have to take those off at work a lot (I work at a Chrome Shop) They suck.
            You have to be really careful not to clamp too hard those things get mushed and its fucked. Then we have to go buy a replacement, or have one made ($$$$$$$$$) Boss is not happy.
            Most of the time though the level of vehicle were doing the customers want new ones anyways, so then thats thier gig, we get the bumper to concours quality then they find the show quality rubber.
            1986 Mercury Grand Marquis "5.0" (160,000)
            2011 Ford Crown Victoria "4.6" (54,000)
            2015 Jeep Wrangler JK Willys "3.6" (48,000)
              Awesome (not)! I might end up doing what Turbo said and take the bumper apart. Then try my darndest to not destroy the strip. I would normally say to use the set that's on my mom's car, but the corner fasteners broke off. Thanks guys.
                Can always silicone the entire stripe back in place if some of the studs decide to break.
                  Just throwing in an idea here. Anytime I've come across hard plastic that has the potential of breaking on contact, I break out the heat gun, and CAREFULLY warm up the plastic. Just enough to squeeze the tabs. If you are not careful, you will melt it in an instant.
                  MIKE
