Hello -- some box bodies were built with a sort of extended roof that was a plastic cowl type roof extension that was put over the rear window that extended the roof rearward and apparently was for the purpose of making more head room in the rear seat.
Does anyone have any knowledge of what is involved with converting this type of roof back to the standard roof? In other words, removing the plastic roof extension and reinstalling a standard rear window.
I'm guessing it would be fairly straight foward -- i.e., removing the vinyl top, removing the roof extension, clean things up and have a shop put in a new rear window gasket and window, find some std. rear window trim and install the trim.
However, if somebody has done this before, I would greatly appreciate any pointers/advice etc., or perhaps there is some reason that this type of modification would be ill-advised.
Any input would be appreciated. Thank you.
