Originally posted by sxcpotatoes
View Post
Modern headlights for boxes
Continuing on with the review. I mocked up the lights tonight on the car.
They basically fit right in. I did have to bend inner lip of the headlight buckets very lightly so projector would fit all the way in.
As far as the light output goes lets start with the halos. They are rather disappointing. Basically just 2 diodes at the bottom that light up the ring. They are quite dim during the day light. I suggest for anyone planning on buying these to pull the projector out and replace the halo ring with some LED rings. They sell them on Ebay.
Next up the actual projectors. As expected the light output blows OEM headlights out of the water.
I also installed HIDs into the high beam housings. These are 3500k yellow HIDs. Once I start driving the car I will post some pics of light output on the road as well as projector cut off.
I got a video of the lights I will upload in a bit.
nice... very nice... if/when I get some bank going... I may very much wanna do this.
bad move on the high beam HID.... please dont be offeneded i dont mean it like that. let me rephrase. i like it alot, they look nice. but HIDs do not take kindly to be used as high beams. you will maybe get a year or so out of them if used as high beams.
the reason behind it is because they have a warm up time and if they are shut on and off repeatedly in a short time, they burn. they have to cool all the way back down to room temp before they can be turned on safely. they will still work fine but your color will fade fast and the bulb will go out twice as fast as their normal life expectancy. that is the reason you saw bi-xenon in my car. they never physically shut off, they move. also, never start you car with your HIDs already on first. turn them on after the cars started. the voltage spikes will fry ballasts.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Yea, that's a valid point and I probably should've mentioned it for anyone thinking of running the same setup. That's probably the reason they don't include HIDs for hi beams.
I don't use hi beams often so I am not too worried about burning the bulbs out. I can get replacement bulbs for like $12 each and I got a few ballasts laying around from years of messing with HIDs so I am not worried about it. That's the same setup that I had on my 96' so I just moved the bulbs over. I had them for several years and they haven't burned out yet. I am sure it's only a matter of time but that's the price to pay for running this setup. lol
That was helpful information. I guess that explains why some hid sets involve a mechanical shade to switch from low to high and back.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Serge, what is the bulb type(size) for both the high and low beam?
Is there a bixenon projector in the low beam housing or is it just a low beam projector and the high beam housing has a different cutoff?1989 Country Squire - Twilight Blue, 347 stroker
I got the Dapper lights too, without the projectors and relay, since I have the relay already. The bulbs that are included are cheap bulbs that you would probably replace. Im going to be getting a HID set up soon, but I needed lights since I can not see at night when driving. Here are some photos on a wagon. I had to modify the adjuster bowl to fit the projector. I attached some photos of where it would hit. I still need to do the other side, but its a plug and play set up. Once I figured out that I needed to cut parts, it would be a really quick instillation.
Harumph, I meant to say HID, not projector. This light would not fit the bowl without cutting. I tried bending, but it wouldnt stay flat in the bowl unless I cut it. It was easy to modify, a few minutes with a Dremel and it was done.
