my wipers constantly suck, im lucky the drivers side is better than the passanger side.. cleaning my windows good helped some.
FUCKING STREAKING DRIVER WIPER
mine is on the drivers side and even when wet they do that shit. the dragging streaking pisses me off. it does it even when i'm using the windshield washer.2000 Mercury Grand Marquis LS HPP.
http://www.cardomain.com/ride/2336322
Friends don't let friends drive donk.
Mean green your glass and go over it gently with some very fine steel wool. That will make sure your glass is clean.GMNRadio DJ, Podcast Co-Host
95 S10 93 Accord
Good news Mangs at last I could solve the streaking driver wiper problem I first spray the whole front glasss with windex and a some kinda like scotch brite sponge and apply in circular movements like when you wash your Panther after do that to the entire front glass I rinse it with water,after that I remove the driver wiper arm and bended a little and reinstalled back again later I went to Western auto(Advance Auto Parts) and buy two Bosch Icon wiper blades and install it later I did a test ride and perfect it won't streak any more even at high speeds now I keep clean the front glass with that way I did it. I would like any of you do the same and later tell me the results.
ATT, SNIPER 308.LORD & COMMANDER OF THE PANTHER FORCES.Last edited by sniper308; 06-14-2006, 02:02 AM.MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
Beleive it or not, you would be surprised what will come off of a clean windshield when you pour some acetone on a white rag and start scrubbing.
Also you have to make sure you don't have something all over your wiper blades. If you clean your windshield and then turn a set of dirty wiper blades loose on it you have just wasted your time.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Next time you get new wipers keep the little packet of cleaner....about 30 to 60 days open and rub both blades with the stuff....It will make a big differance in the way it cleansPresident He Man Woman Haters Club
Life should not be a journey to the grave with the intention of arriving safely in a pretty & well preserved body,But rather skid in broadside,Thourghly used up totaly worn out & loudly proclaiming...WOW WHAT A RIDE!!!
http://www.myspace.com/dabearsplace
only problem i have is a worn out wiper transmission........the ds wiper hits the windshield trim at highway speeds......i have a new transmnission, just need to find time to work on my own cars
scott
