R.I.P Crown Marquis
    R.I.P Crown Marquis
    My Brother is sending the Crown Marquis to the crusher this weekend. It was hit by an amateur driver this past spring while it was parked and it did a lot of damage to the front body work and frame. Sucks to see her go down like this.....
    "Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
    www.myspace.com/nascarmechanic
    That sucks. I love the color matched "racoon eyes" and the exhaust setup on it.
      What tailpipes were used? I like the angled exiting tips.
        Farewell...Another honorable car is sent away to the big junkyard in the sky.
        **A tear shed for those lost in battle**
          Bye Bye CrownMarq
          -Matt
          1968 Fairlane 500 - 1998 Camaro Z/28
            bye bye Grand Vic... that sucks
              Now was that a Crown Vic with a Grand Marquis rear end swapped on or vice versa?
              Nick
              88 Colony Park LS
                It started life as a 1988 Grand Marquis. I got sent through the ditch which destroyed the header panel, so I swapped in one from a Crown Vic and made new bumper mounts for it do the lines would match up. I did the rear window conversion and replaced most of the sheet metal. The exhaust was 2" custom duals, no mufflers, the tailpipes were bent to stock, cut back a foot from the rear bumper and a 45 degree angle pipe was welded in with the tips.
                  Ah, the original crown marquis... I will miss that car, gave me lots of inspiration
                    rip crown marquis
                      Sorry for your loss Mang,Rest In Peace CROWNMARQUIS.
                      ATT,SNIPER 308.PROUD OWNER OF "MERC-75 INTERCEPTOR"
                      MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
                        STRIP HER AS MUCH AS POSSIBLE FIRST LET HER LIVE ON AS A DONOR!
