My Brother is sending the Crown Marquis to the crusher this weekend. It was hit by an amateur driver this past spring while it was parked and it did a lot of damage to the front body work and frame. Sucks to see her go down like this.....
R.I.P Crown Marquis
R.I.P Crown Marquis
"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Tags: None
It started life as a 1988 Grand Marquis. I got sent through the ditch which destroyed the header panel, so I swapped in one from a Crown Vic and made new bumper mounts for it do the lines would match up. I did the rear window conversion and replaced most of the sheet metal. The exhaust was 2" custom duals, no mufflers, the tailpipes were bent to stock, cut back a foot from the rear bumper and a 45 degree angle pipe was welded in with the tips."Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
Sorry for your loss Mang,Rest In Peace CROWNMARQUIS.
ATT,SNIPER 308.PROUD OWNER OF "MERC-75 INTERCEPTOR"MERC75-INTERCEPTOR, BORN IN 2003,DIED IN SEP/21/2010 AT 9:55AM AT THE SORT AHE OF 8 YEARS PROTECTING HIS OWNER TO DIE
