The 93 GM "Tank of Justice II" (TOJ2)
    So, I didn't paint the caliper or the bracket, but dammit, it's fixed.
    I had a hell of a time at the junkyard removing the bracket (even though I had it put in the air).
    ***********IMPORTANT*************
    95 Panther rear brake brackets will fit on 92-94s without any modifications.
    ALSO-
    The rear brackets are the exact same. The left bracket will fit on the right side and vice versa. THe caliper on the left mounts on the back side, while the right side caliper mounts on the front side.
    The Tank has a bracket from the right side of a 95 Grand Marquis on the left side.
    I'm talking rear brake systems, by the way.
    So, removed the old shit, put in newer stuff, cleaned up the diff cover, gasketed it, and filled it back up. The axle needs to be removed in order to change the bracket. So that sucked a bit more than it should have.
    The slide pins received anti-seize on the threads and caliper lube on the shanks. No more BS.
    Also, picked up a 3 knob HVAC unit from that 95. The are compatible with the older style slider suck ones that break often. Next weekend, I'm going to tackle that. And I'm sure you Box guys will like that. Three knobs are way better than the slidey-break-suck ones.
    PICS!!!!!
    Old bracket:
    Old bracket, bottom slide pin. Notice how there are NO threads left. One of the previous slide pins vibrated so much that it wore out all the threads before egressing the car.
    Old bracket, top slide pin. This suckka broke off. OFF. BYE. See ya. F this place. I tried to drill it out with an easy out from the other side. No good.
    Next project:
    Front and rear sway bar end links, alignment, fan temp relay thing, and 3 knob HVAC control install.
    Peace out.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      "Yo couch" should be your next mod.
      Paint it f'n grabber green!
        can't wait for pics of the 3-knob mod. might do that to my 93 as well.
          I'd recommend on the 93. My HVAC control is dead nuts in the middle of the dash, whilst yours in below the radio, and looks kinda nice.
            K, the 4 sway bar end links have been ordered. They should be here tomorrow, pending the hurricane.....
            I have to but the fan relay kit. As much as I want to make one myself, I'm going to have to buy one. Suck. Well, all I need to do is tap new hole in the intake manifold for the temp semsor, so it can turn the fan on as needed.
            I'm in the process of getting rid of the switches, so, I'm looking to make everything better.
            I'm in the process of buying a Marauder steering column with wheel and key. Yea!
            Ok, bye bye.
              I trust your axles were in good shape when you put them back in, or you got more better ones from the junkyard or something? Those things tend to pit and groove which makes them noisy and leaky.
                They were in quite good shape. The donor car from the yard... not so much. The donor car's right side was leaking like a champ.
                  yeah the right side seems to fail first for whatever reason.
                    peg leg burn-outs
                      seen it on what was very obviously a fogiemobile. I just cant picture Grandma Gertrude baking the tire off her Grand Marquis.
                        Or try and find some green leather seats. They do exist but I know it's a rare option!
                        '79 Continental Town Car
                        '90 Crown Victoria LTD
                        '94 Crown Victoria
                          My Grandma's name is Gertrude
                          '94 Crown Victoria
                            I think the leaks are from the open differentials. That is the main drive wheel. Blah.
                            Tom wants me to paint the whole car Grabber Green. lolz. That'll be the day that Tom loves Neil Young.
                            No green leather seats. I am not that "gangsta". I cannot pull that off. However, charcoal Marauder seats with green piping.....
                            Sway bar end links should be here today. Gotta go pick up the fan relay harness thing as well. I think...
                              does she bake the tires off her cars?
                                Back in the early 90s, my Grandparents owned a couple of white CV's. First was an '89 and the next was a '92. I don't recall Grandma Gert doing much driving in either car.
                                '94 Crown Victoria
