The 93 GM "Tank of Justice II" (TOJ2)
    Aluminum. Yes.
    And removable.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      Kool
        the front grill cover I would use for cold/cool weather. remove for mid summer and shenanigans... because RACECAR!
          I am going to test it tomorrow at one of the most grueling and punishing places: the US/Canada border. A place where idle times can exceed two hours because of some random Canadian holiday, of which they feel the need to come to the US to go shopping and leave their trash all over the parking lots.
            Last tank: 454 miles.
            Currently: 488 and counting.
            I want to clear 516.
              Originally posted by SVT98t View Post
              some random Canadian holiday...
              Labour Day.
              '79 Continental Town Car
              '90 Crown Victoria LTD
              '94 Crown Victoria
                Blah. They still invade every weekend and leave their trash everywhere and drive like lunatics.
                BTW: 505 miles and counting...
                  New record.
                  518 miles on one tank of gas. Next stop: 530.
                    New lower grille block installed by nutplates:
                      Do you have a couple of gallons of gas in a can in the trunk? Or do you have an aux tank setup?
                        I keep a 2 gallon gas can in the trunk. I like to live dangerously, but let's face it. I don't want to walk that much.
                        But I would LOVE an aux tank. We'll see...
                          Can I ask why you blocked off the lower grille?
                            The idea is that you want to limit the air going through the car(for cooling, gaps between panels), and try and make the air go around or underneath the car.
                            You also don't want to take too much air from the radiator.
                            So it's a trial and error build.
                              Another combo to try would be to block off the top grille and keep little ducts open in the bottom. I can't remember which member on Ecomodder tried that, but if I remember right, it worked better for their car.
                                I went with the lower grille because it has a larger surface area, and I think it will improve the overall aero better.
