The 93 GM "Tank of Justice II" (TOJ2)
    Cleaned it up more last night. Going to run it through the parts washer then the hot tank tomorrow.
    Sent from my LGLS740 using Tapatalk
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      What is special about a wap motor?
        Nice work mang! Can't believe I wasn't subscribed to this until now.
        X2, what is a WAP block?
        -Phil
          Aluminum
          http://www.mre-books.com/sa82/sa82_1.html
            It's an aluminum block motor. It's lighter than the Teksid, but not as strong.
            Since this is an efficiency build, I'm going for the lightest block that's feasible. Once installed, I'll drop 77 lbs from the car.
              I love a good economy build, I find it just as interesting, if not more, than one strictly for power. I suppose that's because so few people do them. But power and efficiency can go hand in hand, to a certain point. 77pounds is a nice drop in weight! I should have known from the picture that It was aluminum, but I didn't take note for whatever reason.
              Sent from my iPad using Tapatalk
              -Phil
                Oh well I see now why you got that one.
                What is your best mileage so far?
                  Differnce in blocks
                  Here it is, with pictures, the weight difference between the three Modular motor blocks.
                  WAP block at 71.0 lbs
                  Teksid block at 74.4 lbs
                  Iron block at 148.6 lbs
                    Iron = Chunky Monkey
                      Overall, 28.5mpg over 478 miles.
                      Total overall distance on a tank is 518 miles.
                        (also, now 1000 replies to this thread. Tank gonna beat.)
                          more MPG's but less M's from those modular motors. My high mileage one is at 247k but only gets 21 mpg. No oil usage though so it levels out. I guess if you calculate the dollars saved in fuel it might pay for the engine replacement, but frankly I'm lazy and its easier to pump gas in than it is to change engines.
                            And if I didn't run it forever with the blown valve seals, then it might have been a slightly different story.
                              and if mine didn't have that shitty casting flash on the head that we all think grabbed the intake valve on #1, I might still be running NPI in that 93.
                                More progress tonight.
