SVT98t's 2003 Mercury Marauder **DUW**
    No kidding? Wow, and I thought my old man's '93 Buick Roadmaster was strange for switching off the A/C and climate control at WOT...
    1997 Lincoln Town Car Executive Series - Charlene
    Saved from a tragic fate, planned mild restoration. Now with working heat, perfect for the cold winter!
      Its part of the tune to shut off the alternator at WOT, because it's clutched.
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        Nearly everything switches the a/c compressor off at WOT.
          Do you smell that? It's a spare set of C-heads that I got.
          Game on.
            Installed the new torque converter clutch solenoid and the new solenoid shift packs and I still don't have third gear.
            So, I can either rebuild one of the transmissions I have lying around, or install a cheap one from my buddies yard, just so I can drive it.
            Decisions, decisions.
            Oh well.
            And so, it sits.
              No third gear = bad direct drive drum/clutch.
              So, tomorrow, I'm going to pick up my spare transmission that has the burnt up over drive band and start tearing into that so I can get this thing going.
              If I drove it this year, it would be epic.
              It may need a new torque converter as well. I have to have it tested first. But I would really like to not have to replace that.
              I did find out the cause of the original converter failure: plastic parts in the bearings.
              Plastic.
              In the later 03 and 04 models, they used the metal Torrington bearing, so that didn't have the issue.
              F.
              But I'll take pics of ze disassembly and such.
                Annual State of the Marauder Address
                It really hasn't moved since July. Ending mileage of 57,926 with a year total of like 9. Maybe.
                Sigh.
                Rebuild the transmission. Make it go forward using all 4 gears. Go from there.
                I'll say I'd like to have it supercharged by SF13, but that is a long shot for now.
                Only time will tell.
                  Pulled it out and started it. The drivers side HID bulb or ballast is failing. It started flickering like crazy, then quit. It's time to get another kit. F-it.
                  Atleast I still have that pair od SilverStar Ultras laying around.
                    Are those leaves down around the windshield? lol
                      What a Beauty!!! The eyelids are awesome, I totally like them, makes the car look like a kitten and I bet it purrrrrrs like one too, but watch out when those claws come out.... I can smell the burnt rubber already. A lioness in disguise!
                      1995 Lincoln Town Car Executive Series: "Albert" my daily driver
                      1988 Lincoln Town Car Signature Series: "Don Vito Corleone" my Summer Cruise
                      2004 Grand Marquis LS: "The Boss" with floor shifter (loved it) - R.I.P.
                      1997 Crown Victoria: "Victoria, the Armadillo" R.I.P.
                      2003 Lincoln Town Car: "Nikkatello" - R.I.P. (Miss you the most)
                      1995 Grand Marquis: "Gustavo Gonzales, the dirty Mexican" - R.I.P.
                        Ho hum....
                        Just ordered:
                        -I/C Pump pigtail
                        -IAT2 pigtail
                        -New Alternator pulley
                        -New tensioner
                        -Cobra coolant tube, with associated hardware
                        Next week: Fuel pump and EvenFlow Gen2 cooling mod.
                          get that trans fixed yet?
                            Nope.
                            But I was thinking.... I replaced the separator plate, valve body, torque converter clutch and shift solenoids and still no third gear.
                            All the fluid looks good and if the direct drive drum/clutches were toast, there would be dark fluid and crap in the bottom of the pan.
                            When I get home, I'm gonna change out the 2-3 accumulator piston and springs and take a look around. If the accumulator is borkt, then I may win.
                            If this doesn't fix it, I'm buying a built transmission. My curious side wants to take a stab at it first.
                              good luck. hope it's just a borked accumulator.
                                Just ordered an Aeromotive fuel pump. Wooo!!
