Also, did you guys have to reshim your core support a lot? Mine is off about a 1/4" on each side which seems odd seeing as the entire body was lifted the same amount. Also, I take it your not supposed to use the spacer due to the hex holes in the frame.
And on the passenger head bulkhead area, did you guys just reuse the old washers/plates on the bottom? There was no way to fit the ones with the new bushings in. The drives side I snuck through the parking brake cable hole, but no hole or slot large enough on the pass side.
