Big, Obnoxious Bronco
This will be the wagon's replacement. I was looking for one that was rotted out so I could take the axles and go solid axle in the Explorer. I dug around for several days, then happened upon this thing for crazy cheap. I figured it'd be a perfect donor truck. When I arrived to pick it up I realized it's in awesome shape so I decided I'm gonna keep it and build it.
I don't yet know whether it's the 351M or the 400, but as soon as I get it home I'm gonna check the rod stroke so I can know for sure. Being that it's a Custom it's probably just the 351, but that's fine. When I'm ready I can swap the crank and pistons to get the 400.
The previous owner installed a new 4-core radiator but didn't save the adapter fittings from the original radiator, so the transmission lines are currently not hooked up. I already picked up a huge 11x11x1.5 transmission cooler (looks like a 4cyl radiator) to install so the C6 shouldn't have any trouble staying cool. It also needs a steering box, as the one on the truck is leaking pretty badly. Additionally, most of the marker lights are missing, including a tail light. Still, the price I paid is well worth needing to perform these mild repairs.
Then the day after buying this I scored an old school winch to mount on the front of it. With the winch, OBA (using the factory York compressor), electric fans and huge oil coolers, and welding the spiders in the front axle, this thing is gonna be pretty stout by the end of the year!
So on with the pictures!
