Purchased about a year ago. Found at a used car lot in Flat Rock Mich. It belonged to the grandmother of one of the salesman. Had a bit over 70K on it. Had to swap rear ends out of it to put in Creamy. Casper got the wider 90ish posi 2.73 going to try to do better with economy than my best with Creamy. So far redid rear brakes and lines to them starting from the proporting block. Waggon over load rear spring were installed. Not shure if they are the progressive ones or not had a sert of each but one set ended up missing. Rear shocks are needed yet. The upper mout is converted to an eye end like the bottom. No more issues withthe pin end. Have found 3 different shocks that should fit. Want to find out what they are used on before deciding which set.
Meet CASPER the friendly Merc
