The MegaMerc
    My two Escape subs and amps cost me $20 total at the U-Pull yard If you're going for the larger Explorer ones, you need to be looking at the 3rd gen Explorers, IIRC '98-up model years
      Cleaned the summer wheels yesterday, stoll need to polish & wax...
        Replaced driven speedo gear, maybe now it will be close to correct....
          Wheels polished & waxed, rears on car last weekend.
            At the end of another 66 hr week (and 10 +/- hrs travel). Finished another 10 hr day & replaced the PS pump in the Megamerc.
            On a grey day.
            In a heavy mist.
            Sometimes getting drizzled on.
            Ya gotsta do wachya gots to do....
            At least it is finally done...
            Maybe I'll put the summer fronts on.
            Tomorrow.
            Maybe.
            LOL
              Yay! fronts on car...
              Boo,
              Squeal on start up.
              Belt seems tight enough, maybe too tight?
                The long stretch of belt should only deflect a quarter inch IIRC on a new belt. If the belt isn't slipping, it's bearing squeal.
                  or an alignment problem perhaps
                    Drained rad & block as well as I could, fed it 2 gals of Antifreeze, should be good for winter.
                    Swapped all 4 snows on.
                    Repaired Seat switch.
                    Getting it inspected tomorrow.
                    That is all...
                    Everything to do with interior and body electrical including headlights and tail lights. CFI specific discussions and AC/heating systems.
                      While I was away a heater hose blew. My son did his first solo repair. Today I rebalanced the antifreeze level.
                        Make you proud?
                          Jess!
                            Went to start it yesterday, no response, chk'd terminals, pos felt loose, tightened, won't tighten? Term cracked. Luckily I had a bolt on one on hand. All good now.
                              Also replaced both front window motors & switch.
                                Always feels like a sad day when the mags come off & snows go on...
