Were the roads slippery?
Leroy the 2001 TC Signature
01 should already have the pi heads
01s already have the PI intake manifolds and heads.
Throttle body spacers don't do anything.
I'd get a better flowing intake plenum. Like C&L or Trick Flow. And a bigger throttle body. If you can find a 99-03 E-Series van in the Junkyard, apparently they have the 69.7mm throttle bodies. It's essentially a 70mm throttle body for cheap. Or you can buy a BBK, Accufab or whatever other brand throttle body.
It might also be time to move tires up your list.
03 Mercury Marauder- 63k
Originally posted by 79lincolnlover View PostWere the roads slippery?2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.
Originally posted by Lincolnmania View Post01 should already have the pi heads2010 Toyota Camry "Traveller II "
Dead and sold.
ill have to see if i can find one at the pick a part, im sure therell be one there. thanks! yeah tires would be a good idea, wont have money for em till sometime in the spring so thats gonna have to wait, haha. thankfully ill only have to buy 2 since the 2 on the front have 75% tread left on em.2010 Toyota Camry "Traveller II "
Dead and sold.
adding underdrive pulleys to my wish list2010 Toyota Camry "Traveller II "
Dead and sold.
Originally posted by 88Vic View PostNot sure if you have one but if not add rear sway bar to the list. And window tint.2010 Toyota Camry "Traveller II "
Dead and sold.
just ordered myself a optima red top, seein as the current battery has been in for 6 years and barely cranks the motor at this point2010 Toyota Camry "Traveller II "
Dead and sold.
battery died overnight last night. gonna run out and grab a multimeter to check for a draw, only problem is my new battery dont come in till next friday2010 Toyota Camry "Traveller II "
Dead and sold.
I would think there are several places to get a battery, why so long?2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
my dad ordered it on amazon, so it wont ship till after christmas2010 Toyota Camry "Traveller II "
Dead and sold.
just found out that Leroy was owned by a rental car company before my dad bought it...now the puzzle pieces are comin together2010 Toyota Camry "Traveller II "
Dead and sold.
really wanna do some work this weekend, hopefully that battery does come in friday so i can pull him into the garage and start huntin down the headlight issue. thinkin its the lcm seein as the high beams dont work neither. if thats the case i'll have to run out to harbor freight and pick up a solderin iron and order some new relays. also wanna hunt down the power steering leak and change the oil before it gets too cold. thank god for carhartt jackets and hand warmers!
also found out it has no parasitic draw, and that battery was completely toast!put my meter on it i watched the voltage drop from 12.23V to 10.86V in a matter of 2 minutes. makes sense seein as the battery is 6 years oldLast edited by 01Townie; 12-27-2012, 01:14 AM.2010 Toyota Camry "Traveller II "
Dead and sold.
