Originally posted by Mr Bean
View Post
RyPow
1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
2007 Lincoln Town Car Signature Limited, 102k, daily driver
2006 Mercury Grand Marquis LS, 115k, winter beats
1977 Lincoln Continental Town Car, 42k
2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
2015 Toyota RAV4 XLE AWD (better half's)
Yay, progress. I know it doesn't look like I've done much but it's been mostly small things up to this point. Body is down on the frame and bolted into place(except for the one bolt in the trunk. I'll take care of that at the end cause there is some welding that needs to be done. Fuel lines are in. Brake lines are in. Rear bumper is bolted into place. It will likely be coming off again in the future when I paint the car but it's in for now.
I've been doing a lot of cleaning and painting of all the bolts and brackets before reinstalling them on the car. Tomorrow I need to apply some body filler to the firewall then sand and paint. After that the drivetrain is ready to go in. I am planning on replacing the struts so I haven't messed around with front suspension yet other than cleaning the grime off. When I do the struts I will clean and paint everything.
Can't believe I missed this thread, what an awesome build! Amazing how little the frame changed over the years. Keep up the good work!-Phil
I did. My car also had an adjustable spacer there as well. I used that too.~David~
Originally posted by Mr Bean View PostSo I am thinking ahead here. Those who used ENS body mounts, did you use same ones for the very front 2 at the header panel? Factory ones seem to sit higher than the rest.
Yes, when you put them in, jack up the frame in the front, it flexes that much.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Interesting...
So I started ripping Bignslow apart. Discovered and unpleasant surprise. I have coolant in the oil. It's not milky but I am seeing streaks. Could be cause it sat all winter and moisture accumulated in the engine, could be a blown gasket. I am not taking any chances and changing the head gaskets. There goes another $500 pointlessly spent at Summit.
Got me a bunch of gaskets and seals and new KYBs all around.
Hard to believe that the car in your sig pic, is the doner car. One good looking aero.
Originally posted by marquisman View PostHard to believe that the car in your sig pic, is the doner car. One good looking aero.
Its spirit(and parts) will live on in a box.Last edited by Mr Bean; 05-04-2014, 10:58 PM.
Originally posted by Mr Bean View PostIts spirit(and parts) will live on in a box.
Sent from Blaster coming at ya from Autobot City.
Well, can't argue with box love lol
I love that MGM, it was my laptop wallpaper for quite a while
2011 Ford Ranger Sport 4.0 2wd - Magnaflow Axleback exhaust, K&N 63 Series CAI, DiabloSport 87 Octane tune, LEDs, 3000K LED projector fogs, 5000K Mini H1 projectors - Daily
1967 Ford Galaxie 500 Sedan "C-Code" - 289 2bbl/Cruise-O-Matic - Money pit/project
