    Funny, I did the opposite and harvested the faux wood grain panels from the '90 MGM that I was picking apart.
      How'd you go about converting all the tudor interior panels to black? Did you dye it all? What about the carpet? Looks fantastic, glad to see it moving. I'd suggest some lesser sidewall tires though, maybe something like 255/40/18 Those things look like balloons
      Originally posted by SVT98t
        I used PlastiKote black vinyl paint to do all the interior panels. I got new carpet from Rock Auto and will get a headliner redone locally. Rear tires will be replaced with something smaller. 285/50 is an odd size and hard to find too so I will go with Nittos. Maybe same size as the fronts, not sure yet.
          How's the quality on that carpet? Holes pre-cut for various wiring, etc?
            The carpet material is nice quality. It comes with OEM looking padding and molded rubber pad for the driver, like OEM. I opted for the premium carpet which is thicker than the regular one. It's molded to fit the floor and fits pretty good. None of the holes are precut, you gotta do that yourself. I actually prefer to cut the holes myself. It also requires a little trimming around the door sills as they leave extra material there.
              Did you dye your backseat and what'd you do about your door panels. Them being carpet on the bottoms and all?
                All the seats are out of Marauder which are already black so didn't have to do anything with them. I painted the door panels with same vinyl paint including the carpet on the bottoms.
                  Whale seats just fit in no problem??
                    The floor pans are different so outer rails require a spacer for the seats to sit straight. Also have to drill a new bolt hole on the outer rail about an inch over.
                      Sorry, I meant back seats.
                        Oh. Yea those just fit in.
                          Good to know!
                          Do you ever plan to lower the car a little bit? I'm usually not a fan.. But your rear looks a little tall
                            I think that's just the effect of those huge tires.
                              I love the stance of your car, LEAVE IT!
                              It looks muscly with the back end sitting up high with big tires under it.
                              79 Grand Marquis
                                I am close to finishing the interior.
