In the past I have received some squeaks in that area due to the rear springs touching the big washer on the body mounts. I remedied that by re clocking the spring coil away from the body mount. I have a squeak from the discs as well over bumps. I can replicate it by pushing the car side to side/ up and down rigorously. Stepping on the brake while preforming this task resulted in that annoying squeak disappearing. I have yet to dive into what is actually causing it.
Originally posted by Mr Bean View PostI went to a cruise night tonight and discovered a couple of issues. My fuel fill issue is still there. As soon as you give it full blast it spews the gas out. I think I am gonna bite the bullet and order a 91' gas tank. Could someone confirm for sure that the Aero fuel pump and sending unit will fit into the box tank? Also, any idea where I can buy that valve that sits on top of the tank for a 91?
Second issue is I got an annoying ass squeek on the right side. I thought it was coming from the front suspension but now I tracked it down to the rear right side. Almost sounds like it's coming from the seat area but might actually be the fuel tank.
Some shitty news from today and a word of advice for others. For anyone looking to replace their evap core, do not use butyl tape to create the seal for the evap core housing to the firewall. It will stick like glue and you won't be able to get the housing off in the future. I ended up smashing mine to pieces with a hammer. Gonna be heading to the junkyard on the weekend to get a replacement. Luckily, it's modern so there should be a few 2011s there.
kinda why they use it on sound deadener. Once it sticks and cures it's there forever.
whether you want it to be or not86 Lincoln Town Car (Galactica).
Got a couple of updates on the box. I swapped out the evap core with housing on the weekend and tried charging the system - no go. Compressor would barely spin but wouldn't accept any charge. Also, high pressure switch appears to be shot. I will have to get that sorted out.
Now some good news. I tracked down the annoying squeak from the right rear. Turned out to be the spring which was rubbing on a body mount washer. I used Aero springs which are a tad wider than a Whale and that was the result. No biggie, rotated the spring a bit so there is no more contact and was ready to roll. While under there discovered that the tail pipe was also coming in contact with Watts link as well as the axle housing. Refuckulated that as well. Now no more annoying sounds. So stoked!
And now for some cool news. My car made it on BangShift!
Awesome!
Also, extra awesome points for the build link back to here.86 Lincoln Town Car (Galactica).
Well deserved.
And I called the squeak!~David~
Yup.
I posted this on CVN, I'll post here as well, maybe someone can give me some ideas. I am in the process of getting all the bugs worked out of the a/c system. The issue that I ran into was not being able to charge the system. It just wouldn't accept any freon. Pressure kept building up when I went to charge it but that was it. The A/C clutch was also failing to engage properly. Basically the clutch pulley was spinning very slowly and stopping altogether.
Tonight I ripped the whole system apart. It was still holding pressure. I took the compressor apart, it was nice and clean inside. The only thing that looks questionable is the clutch. There is a bit of rust on it and I am not sure if it's normal or not. The compressor came off an 04' Town Car which was a Northern car so I would think there is no way of getting around rust but perhaps someone who knows more about this can chime in.
The coil still looks fine.
AC Clutch isn't that terribly expensive. If the compressor is good, I'd just replace the clutch. It looks like crap and I've never known rust to be good for clutch work. I'd also check to see that the orifice tube is in need of replacing, flush the works, re-lube it, possibly re-seal it, and put it all back together with some new 134a. Might also have a high pressure sensor issue depending on what system you're using.
I checked resistance on the coil, it read 4.5 ohms. Compared it to the 03' Vic and got same reading so I think the coil is still good. Cleaned rust off the pulleys and threw it back together, Gonna put it back on the car and try it tomorrow and see if the clutch kicks in.
I know the high pressure sensor is bad which I will be replacing. I bypassed it before just to test and still had a problem with a clutch.
Does that system have a low pressure switch you can bypass too? (momentary like just in case the orifice tube is clogged) Hook up some gauges and see if it'll drop the pressure on the low side while raising the high side... once stable the low side should be around 35-40PSI with the high side (as a general rule) about 3x ambient temp in degrees F. So if it's 80 out, ~240 psi. The last time I did this check, I had 95F out and ran about 290psi on the high side with about 38 psi on the low. That was on the 93 though with a brand new compressor. YMMV.
put a set of guages on it and see if they modulate. If the high side goes up REAL FAST and the low side drops out real fast... you've got a clog in the system. If the low side doesn't recover within 3-5 seconds, you've got a clog. If the static pressure with the system off doesn't peg the low side gauge, you probably don't have enough refrigerant in the system.
