Needs lowering springs for stock ride height. LOL So much for your car stopping better than mine. They probably need to be bled again. Double triple quadruple check that you have no leaks, even the smallest amount of air will cause a non working pedal.
85.03 Crown Vic Coupe "CVGT"
Also, on another side note. The box pump does not like the rack and pinion. It barely has any assist when still. So I think a smaller pulley will be in order for the future. I'll triple check the fluid again. It wasn't full manual steering, it was just barely any assist.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Might try a PS pump meant for a Mark VII. Those had a rack and peanut and they're physically identical. I can dig up the pressure and flow specs for a panther vs the mark vii later. Its in the shop manuals. If someone could dig up the same specs for an 03+ car, that would be helpful.86 Lincoln Town Car (Galactica).
I'll check when I get home and see if my EVTM/shop DVD has that info.
Item Specification Lubricants Motorcraft MERCON® Multi-Purpose (ATF) Transmission Fluid XT-2-QDX MERCON® Power Steering Gear Fluid capacity 0.75L (1.6 pt)* Turning effort 2.72 kg (6.0 lb) Turns lock-to-lock 2.9 Power steering purge vacuum 68-85 kPa (20-25 in-Hg) Power Steering Pump Flow 9.5 ± 0.75 liters/minute (2.4 ± 0.2 gpm) Fluid temp. -74-80° C (160-175° F) Engine at idle Minimum capacity 5.3 liters/minute (1.4 gpm) Fluid temp. -74-80° C (160-175° F) Engine at idle Pressure at 5,171 kPa (750 psi) Pressure 1,034 kPa (150 psi) Fluid temp. -74-80° C (160-175° F) Engine at idle Relief pressure 9,653-10,549 kPa (1,400-1,530 psi)
1993 (should be the same/similar to any 79-02):
Code:PRESSURE SPECIFICATIONS ┌───────────────────────┬───────────────────────┬───────────────────────┬───────────┬───────────────────────┐ │ Minimum Flow(1) │ Minimum Relief │ Maximum Relief │ │ Maximum Free Flow │ │ │ Pressure │ Pressure │ │ @ 1500 RPM │ ├───────────┬───────────┼───────────┬───────────┼───────────┬───────────┼───────────┼───────────┬───────────┤ │ Liters │ Gal/Min │ kPa │ psi │ kPa │ psi │ Pump │ Liters │ Gal/Min │ │ /Min │ (*) │ │ │ │ │ Model │ /Min │ (*) │ ├───────────┼───────────┼───────────┼───────────┼───────────┼───────────┼───────────┼───────────┼───────────┤ │ 5.7 │ 1.5 │ 8270 │ 1200 │ 9520 │ 1380 │ HBD-AA │ 12.9 │ 3.4 (1) │ └───────────┴───────────┴───────────┴───────────┴───────────┴───────────┴───────────┴───────────┴───────────┘ (1) - At zero speed (vehicle not moving).
1986 CV/GM, non-police
min flow: 6.1 L/min
min relief pressure: 1100 psi
max relief pressure: 1380 psi
max free flow @ 1500 rpm: 11.4 L/min
1986 CV/GM police and Lincoln Town Car
min flow: 6.1 L/min
max free flow @ 1500 rpm: 12.9 L/min
Proof that Lincolns are superior. We got cop pumps.
1991 Lincoln Mark VII Bill Blass
min flow: 6.1 L/min
min relief pressure: 1300 psi
max relief pressure: 1480 psi
max free flow @ 1500 rpm: 9.8 L/min
1991 Lincoln Mark VII LSC
min flow: 6.1 L/min
max free flow @ 1500 rpm: 11.4 L/min86 Lincoln Town Car (Galactica).
Seems that way. Pressure is about right, flow is low though. Not sure if other applications move more juice or not. That might just be the practical limits of that pump design. Not impossible that other pumps bolt up though. The ghost of hydroboost past might know.86 Lincoln Town Car (Galactica).
What is even better is the coyote has no mounting brackets for a hydraulic pump.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I'm glad everyone chimed in about the pump situation. I think Johns right about the Aerostar one, so I'll probably look into this when I recoop some funds..
Well I drove it again today, just for laughs. It's got some good giddy up and go, I really really hate the hydraulic clutch setup. I can't get this stupid slave cylinder to push forward far enough. It's basically just pushing it forward enough to barely disengage the clutch and at the same, riding the clutch. So. Fuck. Hydraulic. Clutches. Until I figure out how to fix the problem. Brakes still don't work. My buddy is coming over to help with that. It's got mufflers on it and a horrendous header leak, which will need to be attended to. Uh... I bolted in the passenger seat.__________________________________________________
Perhaps the pushrod of the slave isn't positioned correctly with the pedal? Something isn't right there, I've had decent pedal feel with hydraulic setups-Phil
Originally posted by Brown_Muscle View PostPerhaps the pushrod of the slave isn't positioned correctly with the pedal? Something isn't right there, I've had decent pedal feel with hydraulic setups__________________________________________________
