Got that leaking, broken ass AOD out. And my HF trans jack was the real MVP!
1983 Mercury Grand Marquis 2Dr "Mercules”
Fuck yo' AOD.~David~
Wooooo__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Sometime this week I am going to index my Ford Racing TKO bellhousing, just need to get new bolts for my bellhousing. I have a lot of little parts to still get, and still a lot of work ahead of me. I have been keeping track of all the little parts as I need them, and it sure adds up!1983 Grand Marquis 2Dr Sedan "Mercules"
Stop keeping track. Its a sure path to depression. Also, evidence to be used against you should the wifey find the records.86 Lincoln Town Car (Galactica).
Yeah, when you keep track and then you find out that you're several thousand deep in a car that's only worth a few hundred bucks.
This thing done yet?__________________________________________________
Originally posted by Grand Marquis GT View PostGot that leaking, broken ass AOD out.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by Bobcat View PostYeah, when you keep track and then you find out that you're several thousand deep in a car that's only worth a few hundred bucks.
This thing done yet?1983 Grand Marquis 2Dr Sedan "Mercules"
Life keeps me busy as hell. However, I was finally able to get the runout checked on my bellhousing. This is why I like Ford Racing products, they are high quality! The numbers are in thousandths of an inch. Tremec requires .005" as the max runout. Clearly, I am good
Hopefully I can get the floor chopped and get the trans in next weekend. Then, I will work on getting the old pedals/booster/MC installed.1983 Grand Marquis 2Dr Sedan "Mercules"
I was wondering what happened with the off set dowel checking dealio. Nice to see progress.~David~
No offset dowel rods needed. Big thanks to my bro Adam (splorer4.0, and those who met him at SF last year) for use of his dial indicator. Plus, it saves me a few bucks. I just need to order a pressure plate bolt/dowel kit this week.1983 Grand Marquis 2Dr Sedan "Mercules"
Those numbers indicate you are way off the 0.005" spec. 35 thousandths is 0.035. Unless that is a ten thousandths indicator. It'll say 0.0001" on the scale. Looks like a 0-1" by 0.001" dial indicator though if I had to guess at it.86 Lincoln Town Car (Galactica).
Is there that much play in the mounting holes? Howd you get the runout close? I see your original numbers then the corrected numbers showing all is well.~David~
