Do you really want to be fueling the Nagivator all the time? You're driving a 20 year old car in salt country, brake lines are to be expected.
The 97 CV "Tank of Justice III" (TOJ3)
I was thinking about getting a MKZ hybrid. For me and the wife. Still keeping the Navigator. Better mileage and no maintenance for a long while.
It's shitty because the lines look great. It's leaking right by the fuel filter, where it's clamped to the frame.
Sigh.
03 Mercury Marauder- 63k
If they’re factory lines, they’re the uncoated type. They’ll go quick when exposed to salt.
My Cars:
It always takes time to get a special car well sorted. Sounds like you are well into it. Getting all the small stuff out of the way.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
This car has yet to see a proper Buffalo winter. It was down all last year.
Sounds like P71 time2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018
Uh no.
Bah. Throw a new line at it. Its not hard. If the lines are in good shape in general, then just cut back to good metal and flare in a new section where its rotten. If you have a proper metric bubble flare tool, it takes literally no time to re-flare the line and union it up to a new piece. I only say metric because, well, the lines on a '97 are ALL metric, I've replaced 80% of them on my '97 except for the section along the frame under the middle of the car cuz that was new when I got it. After learning myself how to make the bubble flares with the correct tool, I find them to be quicker and easier than a SAE inverted double flare anyway. I am surprised to hear it rusted that far back tho, it almost always seems to be that they rot right at the transmission crossmember 90% of the time. That's where my '96 went, and by the lack of paint on the frame there, that's where they went on the '97.-Steve
bah... just patch that line and be done with it. Would you rather have a car payment or just pay for the little fixes on this one.
Found a nice solenoid today.
Also found this HPP as well.
Cleans up quite well.
Sent from my SM-J727P using Tapatalk08 Lincoln Navigator L - 233k
Good finds.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
It's safe to say that the air ride works now. It was the faulty vent solenoid.
Thoroughly washed the car yesterday, including the drain channels in the trunk and the door frames. Super clean now.
good deal. I hate the green sludge that grows in the drains.86 Lincoln Town Car (Galactica).
What do you use to clean the wheels?
I've found that hot water mixed with Dawn works miracles on nasty wheels and isn't so aggressive as to destroy paint. Use a tooth brush on the intricate areas and she'll end up looking much like the wheel you displayed.1985 LTD Crown Victoria - SOLD
