I would certainly be interested in knowing if a later inner fender would work to retain the air compressor and transfer the '90 TC fan shroud and air cleaner setup from The Ice Car to Marge. That likely won't happen until next year at the earliest.
My 1987 Mercury Colony Park
Vic
Originally posted by VicCrownVic View PostI would certainly be interested in knowing if a later inner fender would work to retain the air compressor and transfer the '90 TC fan shroud and air cleaner setup from The Ice Car to Marge. That likely won't happen until next year at the earliest.
My Cars:
Wagon is looking great! Nice to hear the ho swap has a good amount of reliable miles behind it too.~David~
Originally posted by Kodachrome Wolf View Post
I did install a pusher fan a few years back, but the bearings have since started to fail in it. I noticed it sounded kinda rough, so I've disconnected it. Arguably I've found better A/C performance is to be had in these cars with just a heater shutoff. A proper vacuum controlled one would be dope (only have it engage on Max A/C), but no one makes a return style in 3/4" hose, so manual it is.
I mentioned A-Body GM tails earlier on, but apparently that is definitely more of a suitable thing for '98+ cars with a Watts Link. Due to the 4-link setup on these, you can't position the pipes correctly. They happen to contact the control arms to the center chunk. I found a company that is making 2.5" Impala tails, albeit crush bent vs mandrel, but it was a solution that worked.
Originally posted by 87GrandMarq View PostWhere did you find the new impala tailpipes?
AP Exhaust 126665 - Driver Side
AP Exhaust 126666 - Passenger Side
My Cars:
I'm curious myself. I swear I saw a post around here that someone mentioned it worked, but I've not seen anything else about it. Perhaps next weekend I'll check if the local Pull-A-Part has an Aero TC in and I'll go down and try to pull it.
pretty sure it was sly and the part was from a Ranger maybe? Also aren't these 5/8 hoses? Been a while since I actually paid attention to it.86 Lincoln Town Car (Galactica).
I've never done an inner fender swap, but I've seen posts of the driver inner fender being swapped on to give mounts for the airbox when doing an HO swap. I don't see any issue with using the later inner fenders other than some bolt/clip points may not line up exactly. Pretty sure that everything up to 97 and maybe 02 would be a possibility. I know I like that Aero/early whale inner fender for the pocket where I keep an extra quart of transmission fluid in my 93. That's the compressor mounting point.
Where is the max A/C vacuum source? I'd like to plumb something together and utilize its vacuum when switched to Max Ac
My Cars:
Originally posted by sly View PostI've never done an inner fender swap, but I've seen posts of the driver inner fender being swapped on to give mounts for the airbox when doing an HO swap. I don't see any issue with using the later inner fenders other than some bolt/clip points may not line up exactly. Pretty sure that everything up to 97 and maybe 02 would be a possibility. I know I like that Aero/early whale inner fender for the pocket where I keep an extra quart of transmission fluid in my 93. That's the compressor mounting point.
Originally posted by Kodachrome Wolf View PostI did install a pusher fan a few years back, but the bearings have since started to fail in it. I noticed it sounded kinda rough, so I've disconnected it. Arguably I've found better A/C performance is to be had in these cars with just a heater shutoff. A proper vacuum controlled one would be dope (only have it engage on Max A/C), but no one makes a return style in 3/4" hose, so manual it is.
...Vic
I know the easiest source is to the vacuum dashpot that drives the re-circulation door behind the glovebox.1985 Mercury Grand Marquis LS, "Maisa"
the auto climate control cars do have a max AC mode. Recirc door is controlled by the blend door servo. when its at full cold it opens the recirc door. There is a little valve on top of the heater box for it, along with the switch for the automatic fan speed. I think all of the manual temperature control cars had a max AC position.86 Lincoln Town Car (Galactica).
Took care of some jobs that needed doing. Replaced the speedometer cable because the old one was starting to get a scratchy noise to it intermittently. I was going to install a new throttle cable too, but while the Pioneer unit length was cut right and such, the mount for it where it attaches to the bracket with the TV cable is all sorts of wrong. Listed as the right application for the car, but like hell I was gonna try and make that work, so I just lubed up the old one and tossed it back together.
While up at the dash, I also took care of some other minor things. One of the illumination lamps quit working near the 35 MPH side of the speedometer. Apparently the lamp base gave up and one of the ears broke away. Never saw that failure before. While some might cry heresy, I did "upgrade" the cluster assembly while it was out and tossed in a period correct full idiot light gas gauge from a '79 cluster. Compared to the later pictograph warning lights, all of the lights in this case are red, no amber for low washer or low fuel.
I also spent a little extra time under the car and swapped on the high speed governor (E8ZZ-7C063-A) I've had hanging around for like two or three years now. The {transmission} AOD Governor Swap write up did make this a fairly straight forwards task. It only reminded me how much I don't enjoy rolling around on the garage floor doing that kinda stuff though.
The governor I removed did not have the full weight to it associated with a low speed governor. It looked closer to that of a medium speed unit, but never behaved like it should and would shift around 3900 RPM at WOT. Haven't road tested it yet as I'm waiting for a replacement 17 tooth speedometer gear for the VSS. Found out after going up to the 225 width tires that the speedometer is about 3-5 MPH slow depending on speed traveled, so I want to get that closer to 0 or a hair faster than actual speed.
Hopefully I'll take it for a spin this week and see if it's performing better or if this AOD is doomed to sub-4000 RPM shifts forever.
My Cars:
the internal pressure on the trans also has something to do with the shift points. The Transgo kit I put in the Mark VII moved the WOT shit from about 4700 to 5100 and I didn't touch the governor.86 Lincoln Town Car (Galactica).
