Sly's 2003 Expedition XLT
It's 3/16 on 3/8 bracket main mounts (yeah... they're that thick) and 1/4 brackets on the lower strap to the frame. It's pretty damn beefy in the right spots. The lower mounts to the frame should keep a high grill hit from pushing the thing back into the grill short of bending the frame horns.
175 is good weight for a bumper, not too heavy but not light enough to be made of sheetmetal. What's the plate thickness, 1/8" or 3/16"? Looks good tho. Also I would be VERY tempted to weld a vertical plate on top of those bottom brackets, this will stiffen the thing quite a bit which is good as right now a top-heavy impact (say the spare wheel of a lifted Jeep) will try to twist the grille guard portion of the bumper right into your header panel. This can still be made removable with a bit (but not much) of extra effort, let me know if you'd like a drawing of what I have in mind.
Leave a comment:
Originally posted by Tiggie View PostI have a feeling people will be more inclined to move if you decide to get close to their rear bumper.
And that thing is clean underneath.
Originally posted by Mainemantom View PostThat is one hefty looking bumper. How much does that thing weigh ?
Leave a comment:
Leave a comment:
Leave a comment:
The bumper mount holes on the truck needed stretched (ground outward) and the additional bracket (2-bolts on the lower support) to make up the gap on the frame brace.
Leave a comment:
Mind the plugs. Other than that, the truck mod motors are pretty good overall. I LOVE the personal touch.
Leave a comment:
Originally posted by sly View Postwishlist item for the beast... http://bumpersuperstore.com/i-114587...2004-2005.html
Leave a comment:
Leave a comment:
Originally posted by sly View PostThe AC works too well. I have not been able to keep it colder than half way between cold and hot so far. I think if I actually ran it on full blast that I could literally refrigerate the cabin (get the temp below 40F). The AC in that truck is amazing.
Leave a comment:
Leave a comment:
