My 79 Marquis
Vic
1979 Marquis creamy goodness
That’s gonna be a good way to repair it.~David~
I believe they are a form of Rivet. Double sided tape is risky. Could also just tack weld the upper part of a small nail of the same dimensions if metal work is already being done-Phil
Originally posted by Brown_Muscle View PostI believe they are a form of Rivet. Double sided tape is risky. Could also just tack weld the upper part of a small nail of the same dimensions if metal work is already being done1985 Mercury Grand Marquis LS, "Maisa"
I have done the same as Pete has. Not a million times but about 4 of them on my car. The rivet method will do you perfectly.~David~
Originally posted by Grand1 View PostPerfect, rivets def seem the most straight forward.
pooped my cherry with the inside of a door. I see the door lock actuators that a are bunk. Both of the plastic connections literally dissolved, by the rod connection.
Are these the replacements?-Phil
Originally posted by Grand1 View PostIt begins
-Phil
