Just wondering if there is any difference between the 91 and 92 MGM interior wise, would I be able to easily swap seats or dash panels and stuff or is it trickier than that?
Difference between 91 and 92 MGM
The seats will swap over; though that's the only thing I know for sure. Some of the dash pieces should, as well as the instrument cluster. Most of the other stuff though such as the rear sailpanels, the rear deck piece, and the door panels will not swap over from a box. You could also use a '90 as a donor car as well. The 1990 model year was when Ford redesigned the floorpan, which is almost identical in every respect to a '92s floorpan.Save a seal, club a liberal.
