tripminder directions as per request
    Right from my 89 manual
    The top 3 buttons are used to Set (S), or enter information, select english or metric units of measure (E/M), and Reset (R) information.
    The bottom four buttons are used to select the information desired. Each button may select on of two functions. The second function is selected by pushing the same button a second time.
    Button First push Second push
    Time Time, Day, Date Elapsed time
    Trip Elapsed trip distance Average trip speed
    Econ Instantaneous fuel economy Average Trip economy
    Fuel Fuel used Fuel used (same as first)
    Clock
    Displays time, date, and day Automatically. To select clock display when any other message if displayed press "TIME" button.
    To reset ---
    Clock must be displayed, if not, press "TIME"
    Press R (RESET)
    Press TIME button ( hours and AM or PM indication is displayed)
    Press S (SET) until the correct hour and AM or PM indication is displayed
    Press TIME button again ( minutes display)
    Press S (SET) until correct minutes appear
    Press time button (day display)
    Press S (SET) until correct day appears
    Press TIME button (month display)
    Press S (SET) until correct month appears
    Press TIME button (date display)
    Press S (SET) until correct date appears
    Press any button except S (SET)
    Elapsed time
    Displays elapsed time in hours, minutes, and seconds, similar to a stopwatch. If clock is displayed press TIME button once. If any other message is displayed, press TIME button twice.
    To reset ---
    Elapsed time must be displayed
    Press R (RESET) button
    Press TIME button to zero and begin counting
    Once set, the elapsed time continues to count when the engine is off.
    TRIP ODOMETER
    Displays the distance traveled since last reset. To display press TRIP once.
    Up to 1000 miles or kilometers, the display includes tenths of a unit. Beyond that, the display will round off the whole units. The maximum reading is 9999.
    To reset ---
    Trip odometer must be displayed
    Press TRIP button to zero and begin counting
    Ill add the rest in a bit. Possibly in the morning.
    1989 Grand Marquis LS
    This is a good manual for when I get my tripminder, thanks for posting this.
      Yup, thanks! I was able to set the time and date on mine this morning!
        good info to have. first time I fugured out how to set the time it took me an hour. turns out the buttons were touchy. it took a while to get used to it.
          You can also do a diagnostic with it too. I forget the buttons to push but I've done it with mine.
            Diagnostic? You mean like a code scan??
              Yeah, it will let you know if your fuel flow sending unit is faulty, trans sensor and shit like that.
                I'm gonna try to get more of it up tommorrow. Ive got like 3-4 pages more to copy from the book. My hands get tired.
                  If I still had a manual I could scan it to a PDF...
                    Where's teh rest mang?
                      thanks again for the writeup. Finally set my clock to correct for dst
                        Hey, here's a little tid bit of info, don't know if I read it right, and since I don't have a battery in Vicky right now, I can't test it. I was reading through an '87s manual about the tripminder, you can view the time with the key off if you press the time button.
                          Yep that is true..I do it all the time. Its pretty cool, some newer cars dont even have that option.
                            more info on this subject please.
                              Found out how to do self test. Press and hold both time and english metric button. Youll see '8's and crosses. There are more tests to go through if you have the Lincoln message center. But here's the pdf file I found about it... http://thelincolnmarkviiclub.org/doc...rSelf-Test.pdf
                              Courtesy of the LincolnMarkVIIclub.
                              It does work with the 7 button vic tripminder.
