How Do You Remove The Light Switch 90-91
    I need to remove the light switch assemble ( the rotary knob with the pull out center) to get this trim piece off, Anyone know how to do this I don't want to break anything. Thanks in advance, my dash is all apart so its a bit rushed.
    1985 GMC 1500
    you gotta reach one hand up inside the dash (remove that panel by your knees to get access, 5 bolts) and push a button on the part of the switch behind that dashboard panel that will release it, pull it out
    does it sound awkward? it is. very it's about as fun as replacing the bulb in your HVAC box (another bezel comes off for that, then reach behind it and to the right of the part for high/low/max is the twist-in socket, same as in the dash)
      Alright, Ive got everything off as far as gaining access, I just needed to make sure there is a release button before I go a yankin' . Thanks.
      1985 GMC 1500
        this rotten bastard right here
        left side of the pic is the front of the car, right side is the rear. the button closest to the switch
        I could be wrong, btw...this is me going by feel. You can't really see shit in there.
        post
        Last edited by 87gtVIC; 02-27-2010, 02:06 PM. Reason: no need for three posts within 1 minute on same thread
          Yup, I got her out, old speedo is out too, Im preping the PI speedo, got all the LEDs in and such. Thanks, I had no problems pushing it though, or seeing for that matter, Maybe its just from doing this shit a lot though. My moms 85 olds is one of those repair by feel cars. Ill get some pics up later tonight.
          1985 GMC 1500
            there's an easier way to do this. The knob itself is held on with a little metal tab on the back where it attaches to the shaft. Use a pick to pull the little tab back and remove the knob. Then you can slide the panel off over the switch shaft.
              I found the release button very easy to get at, did not have to contort or anything. Maybe its just me, but I am very giant so others shouldn't have much of a problem. I also had to reach up there like 3 times, because I put the switch together to test it. The HVAC light was just a guessing game though, since I did it without removing any vacuum lines.
              1985 GMC 1500
