I need to know how to take apart the steering column and remove the MF switch (I assume it'll be obvious once it's apart) in a '90 Panther.
pulling apart steering column?
- 2008 Mercury Grand Marquis Ultimate Edition - Daily driver - 4.6 2 valve Mod motor, 4R75E, 2.73s. Bone stockTags: None
if iirc, its like the older stuff. pull the plasic shoud off and its held in with a couple screws and has a couple connectors pluged in
just pulls off?sigpic
there should be a number of screws on the bottom and it should split in two
Awesome, thanks man. I will probably get the shroud too since mine is a bit scratched up.sigpic
