anyway to repair a cracked dash without replacing it?
    the pd that the car belonged to drilled a couple holes in the dash(fuckers) and some of the holes turned into cracks :drug: how do i fix em?
    Save a seal, club a liberal.
    Would this work: Hot glue gun. Spread the cracks open a bit and pump some glue into the crack. Push and hold the crack together until glue dries. Take a razor blade and trim off excess glue.
    Are we talking about a '91 style dash? You could check at an upholestry shop. They might have some tips or even products. Could also check out a hobby store for products.
      yeah its a 91 dash. if it was an 79-89 i had a while back a mint blue pad and then it got cracked
        Lucky you, dash covers are readily available for '90 and '91+. Just check ebay, or google.
        '95 Ford Bronco XL -
        sigpic :rebel:
          Pretty much once they crack you either toss it or cover it up. The plastic and vinyl shrinks so you'd never really be able to close the gap up. I guess you could stitch it and make it look like Frankendash or something. Add a couple bolts sticking out of the sides for character.
            There is a special filler made for dashes, i cant remember what it is called right now, but i know it exists. it would be too expensive to buy to do your dash, but a auto upholstery shop could most likely point you in the right direction
              Could always custom build a dash out of stainless steel or diamond plate. :knowital:
                Might need shades with the sun reflecting off it.
                  lol, i had thought about that too. what i might do is get one of those dash carpets with the ford logo on it
                    sigpic :rebel:
                      Originally posted by BoxMang
                      http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7957733318
                      hmm
