What's up fellas, glad to see a Marquis forum. I just bought an 01 grand marquis gs and I want to install green footwell lights. I already have white lights down there. Is there a simple way to swap these with green lights? Also, is there a way to swap the dome light?
Footwell lights swap
I'm not familiar with the newer Grand Marquis, but often the bulbs will have their size/number stamped on them. Pull the original lights and see if you can find any numbers stamped (often in ink) on them.
My guess for the footwell lights would be 194, if that is correct just throw the terms "194 green LED" into a search of ebay.
These: ebay ad is the same thing I have but I have blue:
http://www.grandmarq.net/vb/showthre...l=1#post705896
On the older panthers the dome light is 561 (http://www.grandmarq.net/vb/showthre...l=1#post699544) but I'm not sure if the new cars use that same bulb for the dome lamp.
Another place to check out that others here have recommended is http://www.superbrightleds.com/
Like the newer panthers I have no experience with that site either, but I'm sure someone with some experience with that site will chime in.Vic
Yep. Just like VicCrownVic said, usually there's a LED equivalent of the bulb type that you can just swap in with your color choice. EBay's a good place to get them cheap if you don't mind cheap china LEDS. (I've used them in my dash and glovebox and think they looks pretty good honestly).
