Can i put 96 seats into my 88? Both are ltc with 6-way power on both sides. I know "anything is possible" but i'm wondering if it is a straight bolt/plug-in or is it too much of a frig to frig with?
Box/aero seat swap?
It's not a straight swap. The floor bolts are different locations. You would have to swap the rails from your old seats to the LTC seats. And without seeing the wiring connector diagram for the 6-way on the LTC and comparing it to the diagram on the 88, I don't know that it would fit much less be electrically compatible. There's definitely a "needs to be modified" part to this swap.
Originally posted by Mr Bean View PostNope. Won't bolt up as stated above. Rails are also different. I had Marauder seats in my 85' but it required cutting and welding the rails.
i can probably get rails swapped, but if i'd need to cut/weld/drill mounts, me no can do. 96 seats into a box.
Also is the wiring totally different, not just a matter of splicing in a new plug, but something else?
again, 96 into a box. thanks for the help96 MGM
Cruisin up and down the road...
1990-2011 seats will physically interchange. Just requires electrical wiring changes. Prior to 1990 floorboard is different.
96' wiring will be different since 96' seats have controls on the doors. I would avoid newer Panther seats and looking for a set from another car. If you have to mod the rails anyway might as well get something supportive and comfortable.
90 and newer rails aren't level. If you place a seat onto the ground it will sit lopsided because one side is higher than the other.
You want seats with controls on the side, otherwise you're going to have to transplant your stock controls to the side of the seat yourself. Its possible, it just requires a little surgery to do it. Definitely want the 80s rails though, its just not going to fit to the floor without a bunch of messing around otherwise.
The only direct no effort involved swap is 1979-89 Grand Marq / Crown Vic. Everything else is at least a little bit different. Even 80s Towncar stuff isn't quite the same, they had door mounted controls.86 Lincoln Town Car (Galactica).
To elaborate on the '90-up seats, you can't just unbolt the tracks from them - the nice folks from Lear (IIRC they are who made them infernal things) decided to build those into the hinge/recline mechanism for the seat back. On the box seats the seat back is attached to the seat bottom, and the rails bolt to the bottom as well - unbolt factory rails and bolt whatever rails fit wherever you wanna put the seat in (such as a pickup truck for example). Not so much with an aero-up seat, if you pull the four bolts on its underside that appear to hold the rails to the bottom the only thing that will happen is the seat bottom will come off the rest of the seat. So in the end you gotta play steel surgeon to make a newer seat fit into a '89-down car, which is majorly annoying but certainly not impossible.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Is that only on the power recline ones, or do the manual reclines work the same?86 Lincoln Town Car (Galactica).
TecNickal used ‘93 Town Car seats in the ‘87. IIRC, he’s mentioned a few times he had to swap the seat base and tracks around so he could use them. They work well and are plenty comfortable.
My Cars:
I swapped an earlier box power seat bracket onto my first '90. It worked and the plug even fit, but the controls worked backward and i had to shim the fuck out of the bracket to get it level. Think i had to re-drill some of the holes for the seat to mount to the bracket too. Anyway you cut it, just get shit that fits right, otherwise you end up in a weird convoluted hassle.
Piggback question; what year did they go to non-seat-mounted controls? Wondering if i can find something like bucket seats from an early aero that'll fit and work in my '90. Hate my seats.
My 88TC in question has the seat controls mounted on the door panel.
The bracket change thing sounds like more work than I'm able to do, or pay someone to do. Sounds pretty confusing actually.
My 88 velour seats are in nice shape just not entirely comfortable on longer trips the way the early aero leather ones are.
thanks for all the input-96 MGM
Originally posted by gadget73 View PostIs that only on the power recline ones, or do the manual reclines work the same?The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by Kodachrome Wolf View PostTecNickal used ‘93 Town Car seats in the ‘87. IIRC, he’s mentioned a few times he had to swap the seat base and tracks around so he could use them. They work well and are plenty comfortable.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by BoulevardRide View PostMy 88TC in question has the seat controls mounted on the door panel.
thanks for all the input-86 Lincoln Town Car (Galactica).
That's funny, Ash finds the velour seats in my Townie to be ultra comfy. Most days I do too but for city trips I find myself adjusting a lot. Seat position and the position of your butt matters a lot. Try to stick your butt right in the corner where the seat cushion & back meet nice & tight. Then angle the seat such that it sort of resembles a bucket, so rather than your ass slide toward the steering wheel after bumps and such it wants to remain nice & tight with that corner. Gadget's solution sounds like the ticket.1985 LTD Crown Victoria - SOLD
