I bought a set of 'tamper resistant' torx bits today at Advance Auto for $9 and it had the the right size to remove the ignition switch. As I mentioned before, it literally fell apart with the plastic separating from the metal, so I had only the metal bracket to remove.
I installed the OEM Ford ignition switch Eric sent me and it worked great. I tightened up the steering column u-joints, but left the trim pieces off for now. I'm going to clean up the trim pieces and maybe re-paint them.
On to the stereo...
I mentioned before I had the shared ground system, it's actually 5 terminals at the stereo harness. 4+ for each speaker, 1 ground. The speaker portion of the adapter was wired in, but I had to still connect the power, switched power, and ground to the wires left in the car.
I used some of the crimp style connectors for these, because I didn't want to try and solder in the front seat. I crimped the three wires together, everything seemed snug, so I reconnected the battery to the car.
Key on, lights come on, CD player comes to life. Eject the CD the previous owner left in, put mine in, starts playing for 10 seconds and then just powers down.
Huh?
Nothing.
Fuse at the back of the CD player is good. Fuse at the fuse box for 'radio' (15amp) looked good.
Car started and ran fine, no other power issues...so I don't know why it just died like that.
Any thing I'm missing?
~Adam
On to the stereo...
Huh?
Nothing.
~Adam
