I took the 85 out the other day for a cruise. I replaced the filler neck seal-but still leaks a lot. Lame
Lots of pictures
Lots of pictures
You can't tell me what to do! #murrica
1994 Buick Roadmaster Limited - I miss my parents 98 gmq-hpp, but this has more torque!
Go give my art page a like!https://www.facebook.com/JCautoart
Help out a starving artist- Give her a commission!Tags: None
Nice! What mods have you done?
did you butter the filler neck seal with petroleum jelly before installing it and made sure that the tank was good and clean in the contact area?
I changed the original plugs, wires, distributor cap, and thing in the distributor, 18" Charger Steelies, 1979 clear corners and billy got a 79 grille for it. and uhh, touch up paint.
aka no mods, stock...slow...We've considered doing EFI swap on it.
Cleaned it all and lubed with oil..today I caulked it all up..yeah, gasoline might eat away- but I can just put more on. hahaYou can't tell me what to do! #murrica
is it leaking from the tank side or the neck side. if it's the neck side... might just try unbolting the neck and twisting it back and forth a bit and bolt it back.
Originally posted by sly View Postis it leaking from the tank side or the neck side. if it's the neck side... might just try unbolting the neck and twisting it back and forth a bit and bolt it back.You can't tell me what to do! #murrica
