Thanks Scott. To me "awhile" is a week off from work. I go back Oct 2nd. I'll be working just about everyday getting the Fairlane to run by next weekend. I've only had 4 days off to work on it since Aug 7th, so I have to get that done. I'll make it out to the shop one day for sure. I'd like to try out your keg setup, and chit chat for awhile.
521 Stroker Motor for the Fairlane
It's an assortment of parts Blaze, so I'll break down for you what I bought.
The slave cylinder on the bellhousing was $50, and the rod end was $20.
I'm using a Wilwood clutch pedal which was $57, and the master cylinder for that was $67.
I also bought a 3 foot braided high pressure line which was $17. I hope it all works, because on paper it should.1966 Ford Fairlane 500XL - 521 Stroker/4-speed
1997 Ford F250XLT Heavy Duty - 460/E4OD
2008 Ford Crown Victoria LX
Okay, little update tonight. Here's what's been going on since my last post.
I spent 2 1/2 hours bead blasting my headers, and my brother's shorty headers. I picked up some Eastwood High Temp Header Coating, so I hope this stuff holds up. At least it will look good for the photo shoot.
I finished up welding some bar stock to mount the clutch slave cylinder, and welded up the clutch fork to smooth it out, and repainted it. I'll post a pic tomorrow of the newly painted red Lakewood Scattershield, with my hydraulic clutch setup. I hope this works nice, because I had this idea in my head for months now.
I mounted the slave cylinder to the bar stock, and drilled and tapped a hole for a 3/8 course thread bolt.
Since the bar stock was straight and the bellhousing is curved, I used this little jewel to find out how much I had to grind the bar stock to meet the curvature for welding.
She's all welded up and grinded to look good when painted.
I also cut out my driver's side shock tower tonight, just before it got dark. Tomorrow I'm going to weld the two pieces I cut out with the plasma cutter, and finish the engine compartment by sanding and painting. I should have the engine in there by Thursday, with a start up by Saturday.....Friday off for pizza, beer, and cruise night. Dad's driving, so I can enjoy.........
Thanks Blaze. Here's some more updates from last night and today. I figured out my radiator mounts and "hood latchless" crossmember. I also mounted the Wilwood clutch pedal and master cylinder. I used an existing hole from the factory clutch rod, so I didn't have to drill a big hole for this setup. I don't know how the heck I would have done that anyway, because there's no room to drill at all. I had just enough room to drill the two bolt holes for the Wilwood pedal.
Here was my dilema, I needed to move the radiator forward a few inches to make some room, and re-connect the crossmember piece that use to be there. I solved both problems by fabricating my own mount, that serves the dual purpose of supporting the radiator at the top too. I made new lower mounts and welded them to the front subframe, but I didn't take a pic of that. If I ever need to pull the motor again, I can simply unbolt everything, and I won't have to lift the motor over this cross piece again.
I used 3/16" steel, and this part of the radiator is not pulled in by the fans. The front of the hood also covers this brace, so it can't be seen from the front.
All of this received a fresh coat of Eastwood underhood paint, so it will look purdy when I bolt it back on for the final time.
Next I worked on the clutch setup. I used the existing hole from the factory, and just had to make a small notch over the top bolt, from inside the engine compartment. I would have like it over a little to the left, but I don't think I could have drilled a big enough hole for the master cylinder bore to pass through. It feels pretty good inside while sitting down, so I should be okay. I need to cut off about an inch more off the brake pedal, but all my sawzall blades were bad. Here's a few pics of that.....
I still have to prep the engine compartment for paint, pull the seats and carpet to make the hole for the shifter, and then install the engine. I hope I can get this done by Sunday. It's back to work on Monday, and I don't know when I'll get another day off.1966 Ford Fairlane 500XL - 521 Stroker/4-speed
Originally posted by MeLikeyStripperChicksI swear I posted already, but I still don't see my post, weird stuff going on. Pat, why cut the strut towers like that?
I finished dialing in the Lakewood bellhousing, and bolted up the trans. I wanted to mount the shifter on tonight, but they sent 3/8 bolts to mount the plate to the tailhousing, instead of 5/16 bolts. I picked up the right bolts before Lowe's closed at 10pm. I even test fit the back two header tubes and everything clears nicely. I won't be able to do much more now, until next week. I have to go to Houston, TX for a week, so I hope to finish it the weekend I come back. Here's a couple pics.
