I'm having an issue with trying to lock the tailgate. The previous owner removed the power lock actuator but the rest of the rods appear to be attached(as best as I can tell according to my awesome Chilton's manual). The problem is even though I turn the key the door will not lock. So does the upper or lower mechanism actually contain the lock portion? I can't tell what the rod from the lock cylinder is moving in that area. Or does the electric portion have to be in there to make it work?
Tailgate lock issues.......
the question you fist have to ask is, when the tail gate is shut, do both latchs lock on to the strikers? with the wagons iv owned, the top latch seems to be the problem child. with the tailgate open, use a screwdriver to set the latchs as if they were locked to the strikers. do they stay in the latched position? if yes, see if you can use the key to lock the tailgate. if no, your top latch is prolly sticky or rusty. another thing is, the top lock strikers are common for loosing the plastic piece, which will prevent the top latch from closing all the way.
Originally posted by marquisman View Postthe question you fist have to ask is, when the tail gate is shut, do both latchs lock on to the strikers? with the wagons iv owned, the top latch seems to be the problem child. with the tailgate open, use a screwdriver to set the latchs as if they were locked to the strikers. do they stay in the latched position? if yes, see if you can use the key to lock the tailgate. if no, your top latch is prolly sticky or rusty. another thing is, the top lock strikers are common for loosing the plastic piece, which will prevent the top latch from closing all the way.
Now do you have any suggestions of an easy sag remedy?( I think I already know the answer to this one.)1991 CVLX Wagon with 17" Black Bullitts, 1974 AMC Javelin owned since 1985.
tailgate sag? if you want a cheap fix, go with what your thinking lol. other than that, sounds like you require a hinge pin/bushing kit. glad i could help a longroof brothern! lol
yea both latches gotta latch for it to lock, try adjusting the strikers........mostlikely the hinges are getting worn out, what a pita to change them, i have resorted to rebuilding them, cause you cannot find good hinges any more
you have a better chance of haveing a litter of kittens then finding a new set of tailgate hardware!!!!!!!!!!!!!!!!!'88' MGM wagon (mine and my sons toy)
"60" chrysler New Yorker (my project)
"78" Chevy 1 Ton P/U (yard horse)
"01" Ford Explorer (wifes DD)
"93" Chevy Suburban (my DD)
