Stick with the DB2 Stanadyne, the electronic DB4 is just a pain in the ass with lower emissions being about the only benefit. Besides, the DB4 will require an ECM and god knows how many sensors, whereas the DB2 only needs one wire to run the engine. If you feel the need for more fuel (not really likely) I've been told the higher-flowing 4-plunger assembly from a DB4 can be swapped in a DB2, however for the price of having the new pump built and calibrated might as well get a Moose DB2 from the get go and be done with it.
On your transmission question, 700R4 will work for you, no electronics and it can be built to handle stupid amounts of torque and power. The tricky part would be attaching the Tv cable to the IP throttle lever, however you can always get one of those manual valve bodies that require no TV cable. Stick with the older-style tailshaft setup for the cable. That actually goes along with the rear gears - put the engine and trans in, drive the car, switch gears to more suitable ones if needed, figure out how far off you are on the speedo, then change the speedo gear accordingly - no point it guesstimating things from the beginning. The GM cable has a square end that looks like it could fit in a Ford cluster, but I'm sure some mods will need to be done to the clip thingie that secures it in.
