Page 258 of 259 FirstFirst ... 158208248256257258259 LastLast
Results 5,141 to 5,160 of 5161
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #5141
    Southern
    Apr 2013
    Columbia, SC
    941
    Quote Originally Posted by Pvt.Hudson View Post
    All Signature and above late 1992-1994 have that style of armrest with fold out cupholders. Change holder is 95-97 which don't have fold out cupholders and wouldn't even work on the older seats as they mount in a U shaped mount on the seat bottom not the seat back.
    Bingo. What I came to post.
    -Nick M.
    Columbia, SC
  2. #5142
    20,483
    Quote Originally Posted by TecNickal View Post
    Thanks for the information. That helps out a ton.
  3. #5143
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,358
    Nice! The arm rests look good! I remember having the armrest cup holders in both my 94 and 97 Towncars. The only thing I wished was that they were designed that they weren't so shallow. 24oz 7-11 coffee cup is a bit top heavy in them. lol
    Side note, I had an issue recently with RockAuto (first time in YEARS) where the bleeder valve on a re-man caliper I bought was helicoiled. When I went to bleed the brakes, the bleeder and the whole insert spun.
  4. #5144
    20,483
    Quote Originally Posted by slack View Post
    The term cup holder is definitely used loosely with these ones. Seems like such a task for manufacturers to get a cup holder right.
    I'll have to look out for the helicoil bit. Would make me unhappy for sure.
  5. #5145
    20,483
    Scooped up a radio out of a 1983 MK VI while on my previous JY trip. Car was really clean. Totaled by a front end collision unfortunately.
    This is a NON premium sound radio so no amp. Took her apart yesterday and found one belt was broken. Took off the old belts cleaned the pulleys up and installed some new ones and I have an awesome back up radio to my other one. This one works even better. Totally clean while making adjustments on any knob. Really excited to have a good back up. Cassette cleaned up nicely too after using some head cleaning tape and demagnatizer.
    Working:
    Then I put the ol'gal in the backyard for the season but not before giving her a quick ONR bath and a quick all in one wax job.
    Attached Thumbnails Attached Thumbnails IMG_4495.jpg   IMG_4494.jpg   IMG_4489.jpg   IMG_4485.jpg
  6. #5146
    20,483
    Set out this morning to install the stifflers driveshaft safety loop....but was met with disappointment. Due to the design of the panther transmission cross-member I cannot use the stifflers piece as it does not sit flush but is obstructed by the thick tubing of the cross-member.
    Piece in question that does not fit:
    https://lmr.com/item/STF-DSLM02/1979...ft-Safety-Loop
    The hoop that surrounds the driveshaft and acts as the safety just does not fit either due to piece not sitting flush against the tranny tailhousing mount. No biggie.....
    I then went and installed my Bilstein #24-014953 Front Shocks and Bilstein #24-014960 Rear Shocks...B6 monotubes.
    Out with the old gas-a-just shocks.... Front ( KG5458) Rear (KG5521)...They are still in fine shape...stored away for future builds.
  7. #5147
    Jan 2008
    New Jersey
    3,232
    Bummer about the safety loops not fitting, are there any others you're considering?
    I think you'll like the bilsteins, Mine are great, you really notice an improvement going around bumpy corners at speed. They have great recovery and makes it feel stable where the KYB's (and other shocks) seem to make the car feel unplanted.
    20,483
    Not considering any others. I happened to spot this one that uses the transmission mount location to hold the bracket for the hoop and that is what caught my eye. Others I have viewed use the seat mount bolts or something like that which would be very specific to the fox body chassis. I could fabricate a mount from scratch if I really wanted it, or modify the existing cross member to more freely accept this style and then make up a hoop that hugs the drive shaft more and gives some clearance in the tunnel.
    Good to hear. I am also curious if it will reduce/diminish my wheel hop issues when breaking loose from stops/rolling.
  9. #5149
    Nov 2006
    Dirty Jersey Yo!
    8,551
    How do those Bilsteins feel? They firmed up the ride in my CV when I installed them.
  10. #5150
    Donating Member massacre's Avatar
    Oct 2011
    USA
    492
    Bummer about the stifflers driveshaft loop. I have one in my fox, but i am also using the stifflers x member.
    I'm sure you can probably make it work.
  11. #5151
    Sep 2014
    Warren, MI
    6,646
    Maybe Stifler's mom would help out with an exchange or return?
  12. #5152
    Oct 2011
    USA
    492
    Here is the stifflers x member for fox body
    You can see how it attaches
    And driveshaft loop mocked up
  13. #5153
    20,483
    And here is the stock 87 tranny cross member....she is thick. I believe 88 and up have thinner ones and the piece may clear but you can see my issue. I have a spare 87 cross member so maybe I will notch that one once?...maybe.
  14. #5154
    Oct 2011
    USA
    492
    Yeah wow. Maybe an additional bracket that mounts above the trans mount bolts to tie in the loop?
    I have a new 93 trans x member here, but it looks just like the one in your pic.
  15. #5155
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,546
    planning on fixing pinion angle? I'd look at welding a couple tabs to the stock crossmember and modify the loop (make something from scratch probably just as quick) to bolt to those tabs.
  16. #5156
    20,483
    Quote Originally Posted by massacre View Post
    Possibly.
    Yes. Since I have the adjustable rear upper arms I do plan to measure and make right the pinion angle. This too will certainly help hush any wheel hop I may have left after the new rear bilsteins....I have not driven the car since the new rear shocks are in. Car tucked away in backyard for winter.
  17. #5157
    22,706
    Create an intermediate bracket that arches over the crossmember?
  18. #5158
    40,977
    what attaches to those two holes in the tailshaft of the trans? If nothing, honestly I'd be way more inclined to make a loop mount to that vs cutting the crossmember.
  19. #5159
    Oct 2011
    USA
    492
    I went with that brand x member and driveshaft loop because it is NHRA legal when they are used together.
    If you're not going to race it, i'm sure you could modify it with no issues.
    If you drilled holes through the Panther x member and welded in some tubes (to keep strength) you could probably bolt the loop to the x member itself. When the loop arrived, i was suspicious since it only mounted with 2 bolts. But it is a sturdy piece.
    I have adjustable control arms as well, had to reset the pinion angle after installing the loop. Not by much tho
  20. #5160
    I post a lot... Toploader's Avatar
    May 2013
    1,896
    Dave!!!!!! Jeeze the chassis and trans look clean enough to eat off of!!............Amazing!
Tags for this Thread
