Page 259 of 259 FirstFirst ... 159209249257258259
Results 5,161 to 5,174 of 5174
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #5161
    Donating Member massacre's Avatar
    Oct 2011
    USA
    569
    Whole car is immaculate. One of the most killer looking Box Panthers imho
  2. #5162
    20,631
    Thanks
    Unseasonably warm here...Popped outside and jacked up the car.
    Measured angle of crank, driveshaft and then pinion.
    Got crank relation to driveshaft to .25 degrees. Ideal is zero acceptable is up to .50 degrees. I did this by adding a 1/8" shim I plasma cut up to go between the trans and the trans mount. I recently removed a tranny mount which set the tranny 1/4" lower.
    Got pinion angle to -2.50 degrees. Very little adjustment was needed on the upper rear arms and I am all set to go.
    While the car was up so damn high I went around and greased everything...u joints, rear control arms, upper/lower ball joints, sway bar endlinks and frame mounts, tierods and pitman arm. Put neato caps on everything too.
    Think the battery is letting go. The deltran battery tender said battery was fully charged but she had no guts to turn it over. Popped on the jump pack and it fired right up. I believe the battery is from 2016 when the engine was changed out.
    Attached Thumbnails Attached Thumbnails 66637506240__4F9505D2-7FE8-4BF3-8655-6405F67DCBED.jpg
    Quote Originally Posted by ootdega View Post
  3. #5163
    It's all about the Benjamin! monterey1962's Avatar
    Arctic Wasteland
    5,962
    Your attention to detail with cars amazes me. Car looks great.
  4. #5164
    20,631
    Thanks.
    Had to put a new battery in the car today. I had to use a jump pack the last few times to start it. The battery tender/maintainer said battery was fully charged, and it was. It just failed the load test. Battery was dated April 2016. Believe that was around the time I put the motor in. Cant argue about that considering it just kinda sits all week and then gets ran on weekends if the weather is good.
  5. #5165
    Dec 2021
    454
    Seems that it is a good policy to change batteries every 3-4 years and not wait for a fail. Not like it used to be where you got 8-10 years from a battery! As current things stand, you got your $'s worth!
  6. #5166
    Nov 2006
    Dirty Jersey Yo!
    8,589
    Thanks.
    At least I know what to expect out of my NAPA battery; as my CV will be driven in the same manner.
  7. #5167
    41,213
    Anymore it seems like if you get more than 5 years out of a battery you're doing pretty good.
  8. #5168
    20,631
    I did a thing.
    It is minor yet something that has been annoying me for quite some time.
    I added back the tilt forward seat levers.
    I could not locate a set of two door hinges so I did what many recommended...using the welder.
    While on a junkyard trip (in New Orleans....was there for work) I cut off a couple seat back tilt levers from a mid to late 90's mustang.
    I welded on the little bits I cut off and then used the mustang knob as well. It works and I can get to the back seats easier now.
    Attached Thumbnails Attached Thumbnails IMG_5079.jpg   IMG_5078.jpg   IMG_5077.jpg   IMG_5076.jpg   IMG_5075.jpg
  9. #5169
    20,631
    Also took care of an annoying problem I noticed late last year.
    My clutch pedal was really loose and I did not know why. I mulled over it all winter expecting the welds broke that held the clutch pedal pivot tube in place on the pedal assembly which would require the entire pedal assembly to be removed. This would not be fun whatsoever so I just procrastinated over it.
    Manned up yesterday and while I had the seat out I pulled the underdash carpeting and then to my amazement I found out that just the pedals nut was loose. This was such a relief.
  10. #5170
    41,213
    if it works loose again, maybe a self-locking nut of some type would get it done.
  11. #5171
    fomoco panthers !
    May 2011
    Bangor,Maine
    4,290
    The seat back levers look to be more sturdy than the originals. Maybe they will not bend and break. I also like the center arm rest/console from a Lincoln. I wish I could find a maroon one.
    Don't those clips on the floor mats catch on your shoes ? You might remove the chrome piece on the top and keep them near by.
  12. #5172
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,378
    Glad to hear the clutch pedal was something simple like that. I had a similar experience with my GMQ recently. It was running like crap/hard to start. 1000 things went through my head as to what it could be. Once I had time to actually look, it was just a loose spark plug wire. Easy fixes are the best fixes.
  13. #5173
    20,631
    Absolutely will try that out. I have a clutch pedal height adjuster kit installed so I will have to see if I have enough threads left to fit a lock washer if things come to that.
    Link to said clutch pedal height adjuster kit: https://lmr.com/item/MM-MMCL10/82-93...BoCZ3UQAvD_BwE
    I have you in my thoughts for when I go out to the yards for a maroon set (grabbing any set really in decent shape) as they are just too damn cool.
    I have no experience with the original seat tilt levers. I can only hope these dont break off.
    No issues with the clips catching my shoes. I will say though that the clips are not strong enough. The clear mat still walks up towards the firewall on me.
    Quote Originally Posted by slack View Post
    Glad to hear the clutch pedal was something simple like that. Easy fixes are the best fixes.
    Amen.
  14. #5174
    22,979
    +1 hurray for easy fix.
Tags for this Thread
